How important is the wire? - Jemsite
post #1 of 2 (permalink) Old 04-26-2005, 11:29 AM Thread Starter
When completely re-wiring a guitar how important is the type of wire used? Is simple plastic coverd wire as good as insulated braided gibson type wiring?
Rotti is offline
post #2 of 2 (permalink) Old 04-26-2005, 12:51 PM
Re: How important is the wire?
Any time you make a run without shielding, you have more exposed wire that has the potential of picking up noise. But I'm not a shield freak, and I'm pretty particular about wiring. I've found very little difference between shielded runs from the pots to the jack. That's about the only area you see shielded wire in the cavity. The pickup wire itself should be shielded, although most single coils just have the two separate wires, which is kind of dumb, because single coils need all the help they can get.
Also shielding the pickups should give you more mileage than the cavity. If you're reducing the noise at the source, then you reduce the compounding effect of more noise taken in at the cavity. Shielding both would be ideal.
Most of my guitars have shielding paint or tape in the cavity, so I feel like it's much less necessary to use shielded wire inside for your runs. So I use mostly single wire. Sometimes I take the hot and ground pair running to the jack, and put one end into my cordless drill to twist them into a braid with eachother. I do that for convenience and neatness, but I figure that adds about a 25% shield to the hot run!
frankfalbo is offline
How big(important) are we? 6fingers Off-topic / Miscellaneous 7 01-01-2012 12:09 PM
Is there a specific type of wire needed to wire a guitar? IBNZ_RG Pickups & wiring 6 04-18-2010 01:48 AM
how important is it.....? dickieboy Tech: Setup, Repairs and Mods 4 09-13-2007 05:59 PM
Rewiring Job: What wire is good wire? Gex Tech: Setup, Repairs and Mods 3 06-11-2005 01:01 PM
Replacing a 2 wire pup(V8) w/ a 4 wire (evo) - Installing an floydJ Tech: Setup, Repairs and Mods 3 08-07-2001 12:59 PM
