How to wire this humbucker? - Jemsite
post #1 of 9 (permalink) Old 01-07-2004, 06:51 PM Thread Starter
I'm trying to wire this humbucker using this wiring diagram: http://www.seymourduncan.com/website...vol_1tone.html
The thing is, my humbucker is a really cheap one from a Pirannha (sp?) guitar. I'm just rebuilding this guitar for fun so I don't want to spend money on another pickup, just want to get it working (because it wasn't working when I got it) (someone gave it to me).
Anyway, I'm having problems because theirs only 3 wires, instead of 4 like the seymour duncan. Inside the big gray wire, their is a black wire, a white wire, and a wire with no plastic around it. How do I know which wire does what?
Thanks,
joe
kickz28 is offline
post #2 of 9 (permalink) Old 01-07-2004, 07:01 PM
white is normally HOT . BARE is earth .
HTH
Rob
Jem7RB MK is offline
post #3 of 9 (permalink) Old 01-07-2004, 07:58 PM
The shield is grounded of course, but what you need to find out is what the other two do. They either represent an "in" and an "out" of the humbucker, or the shield is doubling as the "in", one of the wires is the "out" and therefore hot, and the other wire is the coil junction used for coil splitting. If you have an ohms meter, it will read like this:
A) Shield to one of the wires is "x"(roughly between 8k and 21k) while shield to the other wire is roughly half of "x"(roughly between 4k and 11k. In that case you have a shield, a hot, and a coil junction.
B) Shield has no connection to either wire and the two wires read roughly between 8k and 21k. In that case you have a shield, a hot, and a ground.(or in and out) The hot and ground can be reversed if the pickup is out of phase with the others.
If you have no meter, it will come out like this:
A) Shield to ground, then hook one of the wires to hot, and see if you get signal. If so, then disconnect that wire and hook the other wire to hot. It would be twice the volume or half the volume depending on which one you got first. Then you know you have a hot and a coil junction.
B) Shield to ground, then hook one wire up, and you get nothing. Touch the other to ground and all of a sudden the signal is there. Then you know you have a hot and ground.
frankfalbo is offline
post #4 of 9 (permalink) Old 01-07-2004, 09:03 PM Thread Starter
Alright. Thanks to your info I figured out that the black wire is hot, the bare is coil junction and the white is ground.
Now if I look at the Duncan schematic, the white wire would be green, the black wire is black and the bare would I assume be the red and white which are soldered together and insulated. What does this mean? Where do I plug the bare wire? Nowhere? Just put tape on it? I assume it would only be usefull if I had other pickups in the guitar, but since their is only one humbucker, I don't use it?
Thanks,
joe
kickz28 is offline
post #5 of 9 (permalink) Old 01-07-2004, 09:47 PM
Anything is possible, but I highly doubt that the bare wire is the coil junction. It's there to ground the baseplate, maybe the pole pieces, and then to shield the cable run to the electronics. Please advise how you came to that conclusion.
post #6 of 9 (permalink) Old 01-07-2004, 09:54 PM Thread Starter
When measuring from the white wire to the black one, I got between 8k and 21k, and when measuring from the bare to the white, I got betweem 4k and 11k. Or maybe I completly misunderstood?
I am a beginner
kickz28 is offline
post #7 of 9 (permalink) Old 01-07-2004, 10:50 PM
No you got it right, but it still sounds like bare is shield(ground) and white is the coil junction, and black is hot.
You started with white first. It is more important what bare is to white vs. bare to black. Bare to black should be roughly twice that of bare to white, and bare to white should be roughly the same as white to black. If that's the case then "A" is correct, and bare is ground, white is the junction and black is hot. Let me know
post #8 of 9 (permalink) Old 01-08-2004, 03:51 PM Thread Starter
You're probably right because I wired it the way I thought before reading your reply and it dosen't work. Anyway I think I'll just forget that guitar, the tuners are broken and the saddles also, and I don't want to spend a dime on it, so unless I get some free tuners and saddles (or REALLY cheap), the guitar will collect dust
kickz28 is offline
post #9 of 9 (permalink) Old 01-08-2004, 05:51 PM
Frank's kind of a Pickup Guru :-) ... But 99% of pickups have bare as ground,if it helps at all ?
Rob
coil split , coil splitting , seymour duncan , wiring diagram
4 wire Humbucker wiring and superswitch huruhus Pickups & wiring 0 09-14-2011 04:13 PM
Ibanez Humbucker Wire Colours (PSND2) PGdude Pickups & wiring 3 04-06-2011 11:19 AM
Is there a specific type of wire needed to wire a guitar? IBNZ_RG Pickups & wiring 6 04-18-2010 01:48 AM
Restoring a guitar need to knowhow to wire 1 humbucker vol ton & kill switch IbanezFreak777 Pickups & wiring 4 04-18-2007 12:36 AM
Replacing a 2 wire pup(V8) w/ a 4 wire (evo) - Installing an floydJ Tech: Setup, Repairs and Mods 3 08-07-2001 12:59 PM
