Can anyone put up a wiring diagram with hsh and a five way switch, but able to split the humbuckers independently - with a mini switch instead of a push/pull pot?
^Like this but with a mini switch instead of a push/pull.
Just wire the mini switch as per the push pull, or am I missing something here? A push pull is just a combination of a pot and an on-on double mini switch.
But how would i wire a push pull switch (or mini switch in this case) to get those same combinations. Do you know where I could find a wiring diagram anywhere?
Apologies, I understood you had a diagram for the combination you posted first, which has rather special pickups.
To do the second, you need an on on double throw switch instead of the push pull. The pin out will be the same. Why not just use the push pull though?
I wanted to put in a switch instead of a push pull because i like switches, and always feel as if the knob is about to come off with a push pull. I misunderstood your previous post saying its the same as a push pull pot. I get it now, one of the pickup wires from each pickup goes into the switch, then into the 5 way. like this...
Related Threads
Ibanez JEM Forum
1.3M posts
69.6K members
Since 2000
