Hum cancelling question. - Jemsite
post #1 of 10 (permalink) Old 05-06-2005, 09:15 PM Thread Starter
Question Hum cancelling question.
I rewired my 2 humbucker guitar to have a push pull tone pot. So now I can split coil both humbucks when I want to. It sounds good and everything but I notice the middle position (both humbuckers together in split coil mode, center coils) is not hum cancelling. Should it be? Does this mean I'm out of phase? It really doesn't sound thin enough to me to be out of phase.
Rotti is offline
post #2 of 10 (permalink) Old 05-06-2005, 09:50 PM
Re: Hum cancelling question.
Everything's fine, you just don't have the two coils you want. First, find out which coils you have by tapping them with an allen wrench or something. Then decide which coils you actually want.
The push/pull cuts the humbuckers by shorting the coil junction to ground, right? Well instead of going to ground, one of the coil junctions has to go to hot. But not the main hot on the switch or volume pot. It has to return to the hot of the pickup itself. Then you'll have the "other coil" of that pickup. So be mindful which coils you want, and then switch the appropriate wire.
If, after the mod you don't have the right coil locations, you can always flip a pickup around to move the active coil to the other side, too.
frankfalbo is offline
post #3 of 10 (permalink) Old 05-06-2005, 11:17 PM Thread Starter
I have the middle 2 coils. Thats usually the way it's done right?
Rotti is offline
post #4 of 10 (permalink) Old 05-06-2005, 11:21 PM
Yes, so if you want to keep the two middles, you'll have to flip one of the pickups around physically. Pick one that is symmetrical, so it won't look "backwards" if possible. Then that's the one you'll need to rewire so the coil junction goes to it's hot rather than ground.
post #5 of 10 (permalink) Old 05-07-2005, 07:38 AM Thread Starter
I don't quite follow this. what do you mean by "hot of the pickup itself". and thanks for your help. I appreciate it.
Rotti is offline
post #6 of 10 (permalink) Old 05-07-2005, 07:44 AM Thread Starter
Just to clarify I have the coil junction (white and red) going to the push pull switch and then to ground to get the split coil mode. I have the bare stranded wire going to ground, I have the green (hot) wire going to volume pot, and the black wire going to ground.
Rotti is offline
post #7 of 10 (permalink) Old 05-07-2005, 09:51 AM
So the pickup that you aren't flipping around stays the same. Just to get that clear. The white/red junction will still go to ground on that side of the push/pull. But the white/red junction of other pickup, the one you're flipping, has to go to it's own green wire. So instead of the jumper going to ground on that side, make a jumper that goes to wherever your green wire is going to. You say it's going to the volume pot. Does that mean you have a volume for each pickup? And the volume comes before the pickup selector switch like a Les Paul? Because I would've thought you had the green wire going to the selector switch. I guess I was thinking "Ibanez style" guitar.
post #8 of 10 (permalink) Old 05-07-2005, 10:23 AM Thread Starter
Yes Les Paul style setup. Two volumes and one tone. The tone is the push pull.
Rotti is offline
post #9 of 10 (permalink) Old 05-07-2005, 10:34 AM
Sounds good, just run a jumper from that leg of the switch to the green and you're all set. You'll have the "other" coil and you'll cancel hum.
Bear in mind that you may not cancel hum as effectively as when each pickup is in humbucking mode, depending on how different the pickups are from eachother. Each pickup's humbucking mode may be a little quieter if they have matched coils.
post #10 of 10 (permalink) Old 05-07-2005, 10:59 AM Thread Starter
okay thanks thats great. I don't even mind a little single coil hum. To me it's just part of the single coil sound. I just wanted to make sure everything was wired correct.
Rotti is offline
allen wrench , coil mode , humbucker guitar , les paul , pickup selector switch , pull tone , pull tone pot
Hum-cancelling vs standard ones? benfred Pickups & wiring 11 10-10-2013 04:45 PM
Hum Cancelling Question bhuether Pickups & wiring 0 01-31-2009 02:01 AM
difference between hum-cancelling & standard p'ups liam894 Pickups & wiring 5 12-12-2008 11:16 AM
tips please for cancelling pickup hum shredder87_rob Tech: Setup, Repairs and Mods 2 03-21-2007 11:12 AM
hum cancelling single coil phil0333 Pickups & wiring 7 04-10-2005 10:35 PM
