Hum when connected to power supply? - Jemsite
post #1 of 3 (permalink) Old 04-26-2013, 03:50 AM Thread Starter
Unhappy Hum when connected to power supply?
Hey,
I just installed a pair of EMG Pickups in one of my guitars. I'm playing through a M-Audio FastTrack, which is USB powered and connected to a MacBook Pro.
Here's my situation:
- When the MacBook power supply is plugged in, I get a really loud electrical kind of hum, which STOPS when I touch any metal parts in the control cavity (jack, switch, etc.)
- When the power supply is NOT plugged in, the electrical hum disappears, but theres a hissing sound (like hiss from a high-gain amp), which gets LOUDER when I touch some metal in the cavity
It doesn't matter if the volume pots are open or closed, behavior is always the same. I think it's some kind of grounding issue, but I don't know where I should start looking, as to my eyes the wiring seems perfectly fine. I have another guitar with factory installed EMGs, which doesn't show this behaviour. Also I have installed them myself in two other guitars and never experienced this problem.
Thank you for any help or ideas,
Alex
AlexFinger919 is offline
post #2 of 3 (permalink) Old 04-26-2013, 03:58 AM
Reviews: 120
Re: Hum when connected to power supply?
Did you leave a ground wire on the bridge? EMGs don't require this , and can cause issues if you do have the ground in place.
LonePhantom is offline
post #3 of 3 (permalink) Old 04-26-2013, 04:09 AM Thread Starter
No, the bridge ground is disconnected on the guitar which hums. It's also not connected on the other guitars I installed them myself in, which don't have this problem.
On the guitar with factory installed EMGs the bridge ground is connected...?
Does your amp sound muddy and bassy when connected to POWER IN? rg12 Gear, Equipment, Recording & Off Topic 0 06-05-2011 02:20 PM
FS: EHX Micro POG + power supply Toadfish Classified Ads: Guitars and Gear 1 12-31-2010 08:05 AM
WTB: Boss PSA-120(Boss normal power supply), or any supply that will work GuitarEvan07 Classified Ads: Guitars and Gear 1 06-03-2009 11:33 PM
BOSS PS-2/CE-3/TU-2/OC-2/T.C. Electronic power supply/MORLEY Power Wah BOOST Sevenstringer Classified Ads: Guitars and Gear 12 05-09-2008 04:05 PM
power supply... chopvai Gear, Equipment, Recording & Off Topic 3 02-24-2008 09:02 PM
