Humbucker sounds tinny in split mode -- help? - Jemsite
post #1 of 8 (permalink) Old 11-12-2003, 10:49 PM Thread Starter
I have wired a H-S-S Ibanez with a V2 humbucker in the bridge, and when the switch is in position 2 (splitting the humbucker and combining it with the middle coil) I get a tinny sound that I can't figure out how to correct. I wired the switch according to the Ibanez diagram. Please help!
SBlack is offline
post #2 of 8 (permalink) Old 11-13-2003, 03:51 AM
Sounds like you have the pickups out of phase with each other. Try reversing the hot and ground leads on the humbucker.
dot-dot-dot is offline
post #3 of 8 (permalink) Old 11-13-2003, 01:35 PM Thread Starter
Do you mean take the humbucker's red wire off of the "hot" terminal and put the bare sheild (ground) in its place. Then, solder the red wire to the pot instead of the shield? Please let me know if I got this right.
Thanks
SBlack is offline
post #4 of 8 (permalink) Old 11-13-2003, 04:34 PM
What wires do you have from the humbucker?
post #5 of 8 (permalink) Old 11-13-2003, 09:17 PM Thread Starter
I got it! Thanks. I put the shield to the switch and the red to the ground and it fixed the tinny sound -- now it sounds right finally. But if I touch the pickup screws I get a fuzzy noise like 60-cycle hum. How can I fix that? Thanks.
SBlack is offline
post #6 of 8 (permalink) Old 11-13-2003, 11:14 PM
Go back the way you had it, because you just activated the poles, the baseplate, and the cable shielding to "hot" Next, reverse the hot and ground wires on the two single coil pickups instead. They usually don't have a shield, or if they do, they still have an independent hot and ground that you can switch while leaving the shield alone. Shields should always go to ground. In the case of the V2, the shield is connected to the ground wire of the pickup internally, so there's really only one way to wire that pickup. I can't stand pickups that are wired that way. You need to reverse the phase of the others instead.
frankfalbo is offline
post #7 of 8 (permalink) Old 11-14-2003, 04:53 AM
Argh - I didn't know that about the V2. Doh.
post #8 of 8 (permalink) Old 11-16-2003, 09:08 PM Thread Starter
Thanks. I reversed the single coil black and white wires and connected red to hot, white to tap, and shield to ground on the V2 -- ouala! It works perfectly now. Thanks again.
SBlack is offline
What humbucker will make the SSL-4 sound in split mode? fireheart82 Pickups & wiring 4 05-16-2011 08:21 PM
Split humbucker on a Jem? Shr000m Tech: Setup, Repairs and Mods 1 03-08-2011 04:47 AM
Neck Evolution pickup sounds weak and tinny nighttraveler Pickups & wiring 9 07-25-2009 10:05 AM
RG1570 in dual humbucker mode? zepsongs Pickups & wiring 2 08-30-2008 09:25 AM
converting humbucker to split only one coil ubertwerp Pickups & wiring 3 11-26-2006 12:53 AM
