i need some help quick, pleeease!! - Jemsite
post #1 of 9 (permalink) Old 05-04-2005, 04:21 PM Thread Starter
right, im startin to solder my RG370dx with a new pickup, but which wire on the stock pickups is hot?
is it white or red?
the schematics seem to be back to front, the red on my bridge is wired in the place of the white and vice versa.
this is the first time ive done this, so pleeease help.
rickyk is offline
post #2 of 9 (permalink) Old 05-05-2005, 09:54 AM Thread Starter
Re: i need some help quick, pleeease!!
hi guys, right, an update on my problem.
right, i've got a five way switch, so in positions 2 and 4, the humbuckers are split with the single coil.
the pickup im installin is four conductor, so what do i do with the wires?
please can someone help, im missing playin my guitar already.
rickyk is offline
post #3 of 9 (permalink) Old 05-05-2005, 10:16 AM
JJEMMER777's Avatar
Why don't you ask Rich...I am sure he could help
JJEMMER777 is offline
post #4 of 9 (permalink) Old 05-05-2005, 10:23 AM
Is this clear for you?
rufes is offline
post #5 of 9 (permalink) Old 05-05-2005, 11:46 AM
This post is based on the guess that your guitar is wired exactly like in the 2004 rg370dx diagram. Is your guitar wired like that?
http://www.ibanez.com/wiring/wire.asp?y=2004&w=RG370DX
Then the white should be hot.
The red should be the coil tap.
Before telling you which wire of your new pickup goes to which pole, I'll have to know the brand of it.
rufes: wrong diagram!
jemmer77: There are 9000+ members on this board. If everyone directed his questions directly to rich, then
a) this would ruin the purpose of this forum
b) his computer would blow up in a thermonuclear explosion within approx. 0.00002 secs.
you wouldn't want that.
horstausmforst is offline
post #6 of 9 (permalink) Old 05-05-2005, 12:05 PM
jim777's Avatar
Well I wouldn't; he's like 5 miles away from me!
jim777 is offline
post #7 of 9 (permalink) Old 05-05-2005, 12:06 PM
I posted a thread with a similar question on here a little while back: http://www.jemsite.com/forums/showthread.php?t=35753
There is a link to a wiring diagram on my second post that should help you, that is for the DiMarzio four conductor pickups, but could be the other way round for the white/red wires on the switch apparently.
hope this helps
AARRGGHHH is offline
post #8 of 9 (permalink) Old 05-05-2005, 12:57 PM
Calm down...... the diagram is perfect for replacing the pickups no matter what guitar are you using. He's not going to replace the rest of the electronics....
Are you pretending to be a moderator or a teacher here??????
rufes is offline
post #9 of 9 (permalink) Old 05-05-2005, 01:32 PM
Look closely. V pickups and powersounds have different colorcodes. Since he wanted to know the colorcodes for his stock pickups to go from there, a diagram of his guitar (370 not 550) would be a better start. I clearly stated in my post that I made my assumptions based on what was pictured in that 370 diagram.
The 550 pickups have red=hot, white=split codes.
My intention was to follow up with a "solder the white wire of the [brand name here] pickup to the lug that was originally wired to the red wire of the stock pickup, etc." message. Having the right diagram handy would be a good starting point.
Actually, there were indeed some runs of the powersounds with the V-colorcodes, and if this was your point and his guitar has indeed some of these installed (as he'll soon tell us), I apologize in advance.
(offtopic)
Imagine you are planning your first pickup soldering job involving replacing a stock pickup with a 4 conductor pickup and are greeted with "don't ask us, better ask rich instead" and a stock rg 550 diagram without answering the question this thread is about ("the pickup im installin is four conductor, so what do i do with the wires?").. oh well.
calm down. I don't pretend anything.
(ontopic)
coil tap , wiring diagram
FS: Music Man BFR JP7 (Need quick sale - grab it quick) Of Angels Classified Ads: Guitars and Gear 4 10-16-2012 02:11 AM
QUICK! Need a quick answer! Gex Pickups & wiring 2 03-13-2006 02:35 PM
quick quick question! rx Tech: Setup, Repairs and Mods 1 07-02-2005 10:35 PM
Trem removing... just a quick question... - just a quick que Kev Brigden Tech: Setup, Repairs and Mods 1 03-12-2002 03:56 PM
2 questions - one quick one not so quick tagg 7 All Other Guitars (including Prestige) 3 01-22-2001 05:22 PM
