ibanez 3PS1VLX91 (Multiswitch VLX91) - Jemsite
post #1 of 36 (permalink) Old 01-20-2012, 09:11 PM Thread Starter
Developer
Hey all, was just wondering where I can pick one of these up? Is it worth switching my Fender 5 way in my custom Jem for this?
Thanks,
Brett
Verus is offline
post #2 of 36 (permalink) Old 01-20-2012, 09:14 PM
Re: ibanez 3PS1VLX91 (Multiswitch VLX91)
If you can do coil splitting with the switch you have, No.
If not, Yes.
sebastian is offline
post #3 of 36 (permalink) Old 01-20-2012, 09:15 PM Thread Starter
Developer
I am not sure if I can or not, this is the part:
http://www.themusiczoo.com/PDGImages...ACKAGE_576.jpg
Could you possibly help me figure this out, Im not as tech savvy with the wiring and such.
Thanks
Verus is offline
post #4 of 36 (permalink) Old 01-20-2012, 09:23 PM
I think this switch only combines pickups.
I don't think it can spit humbuckers.
It has a different size switch tip than Ibanez switches too.
This may or may not be a problem for you depending on the switch tip you are going to use.
Check out the switches and knobs/tips at
www.guitarpartsonline.com
The tips they sell fit both sizes, they look like a + on the botom.
post #5 of 36 (permalink) Old 01-20-2012, 09:29 PM Thread Starter
Developer
Alright thank you, so i should be buying the VLX91? If so do you know any good stores online that sell that?
Edit: Also do I need a push/pull pot for anything?
Thanks,
Brett
Verus is offline
post #6 of 36 (permalink) Old 01-20-2012, 09:40 PM
You only need the push/pull if you want one humbucker and only one of it's coils on, like a single coil bridge or neck.
The place I listed has 5 way switches, I think they are just like the Ibanez switch.
http://www.guitarpartsonline.com/pro...roducts_id=164
I'm not sure where to ge the real Ibanez part.
I lucked in to a stack of them a while back and they are going in my guitars slowly.
post #7 of 36 (permalink) Old 01-20-2012, 09:46 PM Thread Starter
Developer
Thank you very much, I would just like my custom to be stock to the original. If i would want it to the same as the original i would have to get the vlx91 and the push pull right?
I appreciate your help!
EDIT: Will this work? item number- 2c5898444a
Verus is offline
post #8 of 36 (permalink) Old 01-20-2012, 10:16 PM
A real JEM has no push/pull pot
The switch in positions 2 and 4 split the humbucker and turn on the middle single coil.
This way they work to get her like a humbucker in a way, two different pickups as one.
post #9 of 36 (permalink) Old 01-20-2012, 10:17 PM Thread Starter
Developer
Ok so all i would need is the multiswitch ?
Thank you so much, I am glad you know a lot in an area that I lack in!
Verus is offline
post #10 of 36 (permalink) Old 01-20-2012, 10:24 PM
It looks like any other 5 way switch from the outside of the guitar.
But it plulls off all the coil taping and combo stuff.
I think it does what they call a coil drain to turn one of the humbuckers coils off.
A multiswitch is a tone or volume knob that spins to change pickup settings.
post #11 of 36 (permalink) Old 01-20-2012, 11:27 PM Thread Starter
Developer
Oh so I just need the vlx91 switch for the coil tap and thats all? Thanks
Verus is offline
post #12 of 36 (permalink) Old 01-20-2012, 11:41 PM
Yep, you'll be able to do:
[IMG]http://*****************.com/resourceservicehost/images/Ibanez/web/switchingSystems/HH_SPLIT_5WAYLEV_1V1T.gif[/IMG]
or this:
[IMG]http://*****************.com/resourceservicehost/images/Ibanez/web/switchingSystems/HSH_SPLIT_5WAYLEV_1V1T.gif[/IMG]
Or just about any kind of switching you can imagine.
xXLinkageXx is offline
post #13 of 36 (permalink) Old 01-21-2012, 10:21 AM Thread Starter
Developer
Thanks linkage, mmmmm I can't wait!
Hows this: Item id 1e695effc2
Verus is offline
post #14 of 36 (permalink) Old 01-21-2012, 02:53 PM
Feel free to disagree as much as you want, but I think the VLX91 cuts part of the bass frequencies coming from the pickups.
Typhon is offline
post #15 of 36 (permalink) Old 01-21-2012, 04:20 PM Thread Starter
Developer
Well thanks for your 2 cents, but Im not sure about wiring... I'm a novice. haha so I am not the right person to disagree, maybe another member can help us out!
Verus is offline
looking for (Ibanez RG560 HSS + OTAX VLX91) wareyha Pickups & wiring 2 09-03-2011 12:38 AM
VLX91...why?!?!? Takin' a Ride Pickups & wiring 5 06-30-2011 08:51 AM
VLX91 in S570DXQM Voice Of Reason Pickups & wiring 1 12-01-2010 09:19 PM
Switch 3PS1VLX91 for IBANEZ JEM 7VH 2003 + EMG tchintao Tech: Setup, Repairs and Mods 1 02-05-2005 08:40 PM
IBANEZ S470/EMG pickups/VLX91 switch and a stereo jackplug!! spacecadet2004 All Other Guitars (including Prestige) 0 04-19-2004 01:34 PM
