Ibanez Jem FP pos 2 and 4 real weak - Jemsite
post #1 of 7 (permalink) Old 03-17-2014, 06:10 AM Thread Starter
Hi all
In my 91 Jem FP, pos 2 and pos 4 are real week, weeker than the single one, could someone point to the correct wiring diagram please, or ideas as to what it could be. otax switch
thanks
daz5150 is offline
post #2 of 7 (permalink) Old 03-17-2014, 09:55 AM
Re: Ibanez Jem FP pos 2 and 4 real weak
Hi Daz.
I found this:
BernieMango is offline
post #3 of 7 (permalink) Old 03-17-2014, 11:06 AM
webmaestro's Avatar
It's been awhile since I had a 3-pup Ibanez, but I vaguely remember positions 2 and 4 being a bit lower-output due to the splitting that occurs. Just want to make sure you don't drive yourself mad with something that may be normal.
webmaestro is offline
post #4 of 7 (permalink) Old 03-17-2014, 04:05 PM Thread Starter
thanks guys, ill check it out. In my pmc, strat, or anything else 5 way its not as noticably less as the fp jem
daz5150 is offline
post #5 of 7 (permalink) Old 04-04-2014, 07:13 AM
If you have modified pickups in the guitar, you can try to reverse the wires of the middle pickup. Ground becomes hot and hot becomes ground. This does not alter the sound of the middle pickup, but reverses the phase with the split positions.
Jouke74 is offline
post #6 of 7 (permalink) Old 04-04-2014, 04:04 PM
Reviews: 6
and thus will annihilate the drop of output level of the 2 and 4 positions. I made this polarity swap on the middle pup and it changed night to day the output level.
satch_jr is offline
post #7 of 7 (permalink) Old 04-06-2014, 07:24 AM
Satch_jr, indeed it's also how Ibanez wires the middle pickup in a RG550. I wrote if someone has modded the guitar, because if not, then the Jem should be wired the right way already unless someone really messed up in the factory Anyway, it's an easy thing to do and also to reverse if you have some soldering skills.
Jouke74 is offline
dimarzio , jem , jem fp
Weak tone of my Jem mrtrapp Ibanez JEM, UV, JS & Other Signature Models 19 04-08-2011 12:31 AM
Weak Wrist or Bad technique? jem_fanatic Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 5 05-13-2008 01:45 PM
RG-470 sounds weak... skrewflanders All Other Guitars (including Prestige) 9 02-13-2007 02:23 PM
Weak breeds? Fry Pickups & wiring 6 02-01-2004 01:07 AM
I am weak welshpete Ibanez JEM, UV, JS & Other Signature Models 8 05-27-2002 05:34 PM
