IBZ C2 reverse wound? - Jemsite
post #1 of 5 (permalink) Old 04-29-2005, 03:45 PM Thread Starter
stratoskier's Avatar
Hi,
I was about to reinstall the pickups in my RG760 and have a question. The pickups are the old IBZ: F2-C2-C2. Unfortunately, I failed to mark which position the two C2s were formerly in, and wouldn't you know it, the wires are exactly the same length. So I'm wondering if anyone could tell me if there was any difference in the C2's in those two positions? I get very confused about the reverse winding business, especially with stacked humbuckers (which these are, basically a Dimarzio HS-2).
Thanks,
Bert
stratoskier is offline
post #2 of 5 (permalink) Old 04-29-2005, 04:29 PM
Re: IBZ C2 reverse wound?
Nope, they're all identical. Ibanez's stock wiring doesn't tap the C2 at in any of the guitars I've had with them, so there's no reason to have one reverse wound.
toshiro is offline
post #3 of 5 (permalink) Old 04-29-2005, 04:48 PM
As a side note, the magnets are insulated from the coil. So if you wanted to run them as true singles, and leave off the bottom coil, you could pull and flip each pole piece to reverse the polarity of one of them and reverse the hot and ground. Then you'd get a hum cancelling "RW/RP" sound for the combination.
frankfalbo is offline
post #4 of 5 (permalink) Old 04-29-2005, 05:55 PM
Just another side note: Yamaha split the HS2 to top coil only in their 900 series Pacificas. Worked well, IMO.
JESTER700 is offline
post #5 of 5 (permalink) Old 05-02-2005, 09:55 AM Thread Starter
Thanks for the help, guys! I wired them up the standard way for now. I may try the "true single" method soon though. These C2 pickups are almost too warm as they are now (as hummers): Pretty odd thing for a "single" coil. You just don't get a lot of single snap out of them, do you? On the other hand, I like them in the middle position when used alone, since most middle singles tend to be weak in position 3. With standard single coils, I generally avoid that position. But as a neck pickup, they don't do exactly what I want.
Bert
neck pickup
Should middle single coil be reverse wound ? JSchwalls Pickups & wiring 2 02-11-2010 08:40 PM
is reverse wound.. -Rhaab Pickups & wiring 1 04-01-2009 07:13 AM
FS: Australia Dimarzio SDS-1 Reverse Wound (Brand New In Box) Pirelli Classified Ads: Guitars and Gear 0 12-01-2007 07:05 AM
Floral JEM with wound 3rd domwint79 Ibanez JEM, UV, JS & Other Signature Models 8 07-17-2004 05:50 AM
Wound G Lauri M Gear, Equipment, Recording & Off Topic 4 06-12-2002 02:29 PM
