Installing Standard Humbucker in TrueDuo Circuit - Jemsite
post #1 of 3 (permalink) Old 11-01-2012, 06:13 PM Thread Starter
Sorry if this has been covered, but I could find no info on how to do this, so here's how.
Some of you may not know that the TrueDuo humbucker is a three coil pickup. One side of the humbucker has a coil underneath it that, when the coil tap on the vol is activated, makes a stacked humbucker for hum-cancelled single coil tone. When the bridge pickup is used in conjunction with the middle single coil, it is turned into a true single coil to maintain hum-cancellation. The wiring to do this is fairly complicated, and I'm not going to describe it as most folks will just want to know how to put in a standard humbucker. This complex wiring could have been avoided if Ibanez would have just used a stacked humbucker in the middle position, but they didn't.
My customer brought in a Carvin M22 4-cond pickup to put in the bridge position of his sv5470a J-Craft. I took meter readings of the TrueDuo pup that were odd, so I disassembled the pickup and found that they had spliced some wires under heatshrink. Long story short, my customer and I decided to make the Carvin pickup split when the vol pot was lifted and also when the 5-way switch activated it with the middle pickup to maintain hum-cancellation.
This was accomplished by removing all the wires on the bridge pup side of the push/pull - two orange wires, one green wire and the pickup wires - and they were also removed from the 5-way. The bridge side of the push/pull was then used as a standard coil tap, with the tap wire of the pickup going to the center lug and the top lug going to ground. The hot wire of the pickup then went to the lug on the 5-way that previously held the green wire and the ground was grounded on the pot shell.
In order to get the bridge pickup to tap automatically when used with the middle pickup, there must be a coil tap activated by the 5-way. I used the terminals previously used by the orange wires for this. Wire a jumper from the tap location on the push/pull center lug to the lug where one of the orange wires were. Then ground the lug where the other orange wire was. This will send the tap to ground when the 5-way is in the #2 position.
It's a simple wiring setup when you know what the original pickups are doing, but it was pretty time consuming to figure out. Hope this helps someone out.
Geoff
sfguitarworks is offline
post #2 of 3 (permalink) Old 11-01-2012, 09:45 PM
Re: Installing Standard Humbucker in TrueDuo Circuit
Ah! Finally someone who has actually seen one of these in person! (jus' kiddin' to the other SV owners). YES...you have helped. Im currently beating my head against the wall mapping this thing out so i can create the PU setup (Non-TruDuo) that i really want. I know between the 4pdt and the 4 pole switch there are a gazillion options but i cant seen to get what im after.
thanks for the insight.
dvsoul is offline
post #3 of 3 (permalink) Old 11-02-2012, 12:23 AM Thread Starter
One other thing. If you want to do the neck pickup, it is a mirror image on the push/pull, with yellow wires in place of orange. The coil tap and ground wire go to the yellow terminations on 5-way and the hot lead of the pickup goes to the termination of the green wire that starts on the neck pickup side of the push/pull. Hope this helps.
coil tap , pickup , trueduo wiring
FS Gibson Les Paul Standard & Suhr DSH Humbucker (white) Angry Classified Ads: Guitars and Gear 1 03-03-2010 09:52 PM
WTB: Two Humbucker Pickups Standard Spacing ModernGuitarist Classified Ads: Guitars and Gear 2 02-09-2010 05:56 PM
jem circuit diagram Cam-Vai Tech: Setup, Repairs and Mods 3 03-31-2009 03:25 AM
does anyone have an ADA MP-1 circuit Diagram ? the second eye Gear, Equipment, Recording & Off Topic 3 11-28-2003 03:33 PM
circuit board in 2027 - what does it do one less than none Tech: Setup, Repairs and Mods 6 07-04-2001 01:00 PM
