Jack socket for SR-500 bass. - Jemsite
 2Likes
  • 1 Post By sepulchrave
  • 1 Post By j.arledge
post #1 of 13 (permalink) Old 10-28-2018, 04:15 AM Thread Starter
Hello all.
My son recently bought a second-hand SR-500 in superb condition, but we suspect the jack socket will need replacing at some point as it sometimes cuts out if we shoogle (a Scottish technical term...) the plug around. This isn't a problem - access is superb.
However, we'd like to know the specific part required as we presume it's 'switched' since it's an active bass. Is this the case? Does the circuitry get turned on by inserting the plug (ooh-er, missus)?
Many thanks for any advice.
Devs Ad is offline
post #2 of 13 (permalink) Old 10-28-2018, 06:30 AM
Originally Posted by Devs Ad View Post
Hello all.
Yes, the jack socket is switched as you correctly surmised.
Rather than shoogling the plug you may well find that simply dismantling, cleaning and straightening the existing socket will effect a permanent repair.
sepulchrave is offline
post #3 of 13 (permalink) Old 10-28-2018, 01:23 PM Thread Starter
Re: Jack socket for SR-500 bass.
Many thanks, Sepulchrave, for the confirmation.
Is the actual socket itself dismantleable? I'd imagined they'd be crimped together or similar?
Cheers.
Devs Ad is offline
post #4 of 13 (permalink) Old 10-28-2018, 02:56 PM
Cheers.
By dismantling I mean take it out of the instrument, clean it up and bend the tip contact back into shape.
post #5 of 13 (permalink) Old 10-28-2018, 05:57 PM Thread Starter
Not sure how I'd get in to the socket that far to re-tweak the contacts inside?!
Devs Ad is offline
post #6 of 13 (permalink) Old 10-28-2018, 06:22 PM
Try, you can always order a new one if it doesn't work out.
post #7 of 13 (permalink) Old 10-28-2018, 06:40 PM Thread Starter
No harm!
That leads me back to my earliest question - any idea of the part number of a socket which is switched? Most such sockets with three terminals are 'stereo' and not switched.
Thanks again.
Devs Ad is offline
post #8 of 13 (permalink) Old 10-28-2018, 06:46 PM
I just looked at various years of 500's and they all have the same typical Korean barrel jack. Nothing special.
Rich is online
post #9 of 13 (permalink) Old 10-30-2018, 02:03 PM Thread Starter
Thank you.
I was just concerned that most sockets don't have the required 'switching' capacity - just an 'earth' and two 'pin' terminals.
Devs Ad is offline
post #10 of 13 (permalink) Old 01-23-2019, 05:11 PM Thread Starter
Still wondering how these sockets are 'switched' inside and it occurred to me that they might not have ACTUAL 'switching' contacts inside - ie they do not have an actual moving contact that's pushed in to contact with another one when the plug is inserted - but instead might simply be 'stereo' sockets which have the usual three terminals - the earth sleeve, a mid-contact and then the end tip.
What could then happen is that the main earth sleeve and the mid contact are effectively connected together by the plug's main metal pin (which is mono), thereby turning on the power (possibly via the earth -ve battery terminal rather than the more usual +ve), and that leaves the socket 'tip' pin to do its normal 'signal' job.
Does that make sense? If so, then there is nothing 'special' about these sockets - they are simply 'stereo' sockets and don't have moving switching contacts inside.
Anyone know if this is correct? Thanks.
Devs Ad is offline
post #11 of 13 (permalink) Old 01-23-2019, 05:34 PM
Yes, correct.
Devs Ad likes this.
post #12 of 13 (permalink) Old 01-23-2019, 08:46 PM
i have an sr-500 bass, it is just a stereo jack. The ring lug is what completes your circuit for the pickups/preamp. If you don't do a stereo jack your battery stays on the entire time until it runs down.
Devs Ad likes this.
j.arledge is offline
post #13 of 13 (permalink) Old 01-28-2019, 08:43 AM Thread Starter
Phew - thank you both :-)
Devs Ad is offline
sr-500 jack socket ibanez
Ibanez SR-1300 bass bryanonbass Classified Ads: Guitars and Gear 1 01-31-2009 09:43 AM
FS: Ibanez SR 400 bass - CHEAP!!! NickCormier Classified Ads: Guitars and Gear 4 05-12-2008 05:01 AM
Gibson SG with odd jack socket moby All Other Guitars (including Prestige) 0 12-08-2004 01:21 PM
'97 SR 8100 J-Custom bass..specs ? p4t4h All Other Guitars (including Prestige) 3 08-26-2004 11:53 AM
Wireing a jack socket - crossed wires? L8X Tech: Setup, Repairs and Mods 2 01-22-2001 01:32 PM
