Jackson soloist sl2h: pickup choice - Jemsite
post #1 of 2 (permalink) Old 05-29-2016, 02:30 PM Thread Starter
I've recently ordered a Jackson soloist SL2H after falling in love with its ebony fretboard giving it a test run at a local store.
However, I did not fall in love with the default pickup (H-H) configuration: bridge = SD TB4 (humbucker) and neck = SD 59 SH1N (humbucker).
My current main 6-string guitar is an Ibanez Jem 77fp (15th anniversary edition). I love the DiMarzio PAF Pro pickups. I'm aiming for a lead tone similar to that of Per Nilsson (Scar Symmetry) and Paul Wardingham. If I'm not mistaken, Per used to record his leads with a Jem 77fp using a PAF Pro in the bridge position.
Question: I'll mostly use this guitar to record/play (metal) lead tracks with the bridge pick up. I'd like to try out the PAF Pro in the bridge position but have no idea what neck pick up to use. Would the PAF Pro work with the default SD SH1N in the neck ? Should I go with another pup configuration ?
I'm new to Jackson guitars and to guitars with an alder body. I don't know if this pickup configuration is what I should aim for in order to get a Per Nilsson-esque lead tone.
My amp configuration is not completely set at the moment (my old amps got destroyed by a flood).
Thanks in advance for any help
eayottes is offline
post #2 of 2 (permalink) Old 05-29-2016, 04:39 PM Thread Starter
Details on the Jackson sl2h soloist
Alder body with a gloss poly finish.
Quartersawn maple neck (bound ebony fingerboard).
Floyd Rose original double locking 2-point trem.
Factory HH pup configuration (direct mount):
Neck: SD '59 SH1N
Bridge: SD zebra JB TB4
eayottes is offline
jackson sl2h , paf pro , paul wardingham , per nilsson
Jackson USA Soloist SL2H Custom Shop coreblade All Other Guitars (including Prestige) 7 03-13-2013 11:00 AM
Jackson SL2H Soloist Trans Blue twooos All Other Guitars (including Prestige) 2 10-27-2007 04:51 PM
Jackson soloist SL2H and SL2MAH Crankitup85 All Other Guitars (including Prestige) 6 04-08-2006 12:34 PM
F/T Snakeskin Jackson SL2H Soloist Gurj Classified Ads: Guitars and Gear 1 06-18-2005 12:51 PM
