Losing output from PU - Jemsite
post #1 of 9 (permalink) Old 08-03-2013, 10:49 AM Thread Starter
FL6
1987 Ibanez RG550.
My Super Distortion bridge pickup started losing power so I resoldered the hot wire directly to the volume pot and voila started sounding great again.
By losing power I mean it goes from sounding like high gain distortion to low gain crunch, very noticable.
Then I started losing power after an hour of playing on/off, so this time I stripped my wires, cleaned the solder etc, same thing happens, sounds great for a bit then goes south.
I have a new volume pot, new switch, my amp's been tested and I eliminated the cords.
I'm running out of ideas.
I'm going to buy another SD and try that.
Could it be the wires? I replaced alot of them with wiring from The Source.
Or bad soldering? I think my soldering is adequate. There's definitely no loose connections.
Also, if I move the main black wire from the SD100 (the one that houses the other 5 wires) the output does change.
FL6 is offline
post #2 of 9 (permalink) Old 08-03-2013, 01:00 PM
Re: Losing output from PU
Sounds like the switch is starting to fail. Is it a regular YM-50?
tearsx is offline
post #3 of 9 (permalink) Old 08-03-2013, 02:27 PM Thread Starter
FL6
Yes but I installed a new Stew Mac super switch, wired according to their instructions.
FL6 is offline
post #4 of 9 (permalink) Old 08-07-2013, 05:41 PM Thread Starter
FL6
Turned out to be a bad pickup. Can you believe it? The other weird thing I noticed was the 2 coils started to separate a bit, the 2 outside edges started to pull down like this /\
I now have a brand new SD100, switch and vol pot.
FL6 is offline
post #5 of 9 (permalink) Old 08-07-2013, 05:58 PM
Reviews: 120
What are you doing with the old one? If you were just going to bin it could you send it to me. I'd like to have a go at repairing it.
LonePhantom is offline
post #6 of 9 (permalink) Old 08-07-2013, 09:16 PM Thread Starter
FL6
I'm going to see if DiMarzio will replace it.
FL6 is offline
post #7 of 9 (permalink) Old 08-07-2013, 10:37 PM
Reviews: 120
No worries, thought it might have been an old one.
post #8 of 9 (permalink) Old 08-07-2013, 11:50 PM Thread Starter
FL6
I'll see what they say and let you know.
FL6 is offline
post #9 of 9 (permalink) Old 08-19-2013, 07:20 PM Thread Starter
FL6
They have a 5 year warranty, repair or replace.
FL6 is offline
Losing/Lost interest maybe? xyon Off-topic / Miscellaneous 41 03-14-2012 04:11 PM
Losing my faith in Ibanez (again)...someone help SonicProvocateur Gear, Equipment, Recording & Off Topic 22 11-30-2010 12:13 PM
Humbucker Losing output ? scotteggshell All Other Guitars (including Prestige) 3 12-30-2008 04:21 PM
Ibanez Losing Fans Thrash All Other Guitars (including Prestige) 68 01-28-2007 12:43 AM
Losing a loved one shredmaster Off-topic / Miscellaneous 26 06-06-2006 04:30 PM
