Middle coil suggestion for basswood guitar - Jemsite
post #1 of 13 (permalink) Old 06-03-2012, 01:58 AM Thread Starter
i am planning to change the hummed and crappy single coil that i have on my RG 870Z BK ... Already changed the bridge with an EVO1 and neck with a PAF pro .... so will i go for Area 67 or Area 61 ? again the body is basswood , i want the strat kinda glassy tubey tone ... suggestions ....
bonsuer is offline
post #2 of 13 (permalink) Old 06-03-2012, 02:29 AM
Reviews: 98
Re: Middle coil suggestion for basswood guitar
What type of music do you play? What gear do you have?
If you're not diggin' the noisy singlecoil--go with a mini-humbucker.
AlaskaBat is offline
post #3 of 13 (permalink) Old 06-03-2012, 06:18 AM Thread Starter
normally instrumental rock stuffs , but i need a glassy bluesy fender kinda tone for middle coil .... aren't the area pickups hum cancellers ?? :S i guess i wont have any problems that much , heh??
bonsuer is offline
post #4 of 13 (permalink) Old 06-03-2012, 06:21 AM Thread Starter
bdw i dnt have any amp , i play with an old pod 2 , a crybaby , a whammy and a NS 2
bonsuer is offline
post #5 of 13 (permalink) Old 06-03-2012, 06:36 AM
Reviews: 98
Yeah--the area pickups may suit your needs.
post #6 of 13 (permalink) Old 06-03-2012, 06:38 AM Thread Starter
thanks , bdw one more thing , if i put colored pickup decals on , will it by any way harm my pickup or are there any side effects ???just asking ..
bonsuer is offline
post #7 of 13 (permalink) Old 06-03-2012, 07:08 AM
Reviews: 98
No--it's just a sticker.
Why not just get the pickup in your desired color? It would be a better color match, as the decals aren't as close.
post #8 of 13 (permalink) Old 06-04-2012, 08:46 AM
I wonder if it's really possible to get there - the glassy strat sound - with an HumbuckerSinglecoilHumbucker Ibanez guitar. I got a bit surprised when I put a DiMarzio Virtual Vintage 54 Pro in the middle position in my S470. It gave me a singlecoil sound yes, but at least to me, it was not like a strat. I'm not sure if it's the wood or something but well, it was not like a strat...
Oh, and keep in mind that the stock singlecoil is usually matched with the humbuckers regarding the volume, so you might notice a drop in volume when getting new pickups. I did! One way to get around it is to adjust the pickup height closer to the strings, but then it might get in the way for your picking.
But good luck on your quest, hope you end up with something nice!
JonatanOTG is offline
post #9 of 13 (permalink) Old 06-07-2012, 10:04 AM
Based on what you're describing, the Area '61 is PROBABLY what you're after. However, it's worth keeping in mind that the sound you're thinking of is probably a neck pickup sound, while you'll be putting this in the middle. The body wood will make a big difference too.
I've currently got a Fender Custom '69 neck and Texas Special middle in my Strat, but at some time today I'll be swapping them for an Area '67 neck and an Area '61 middle (the Areas are not position specific - that's just where I plan to put them). The fenders are pretty awesome, but I had the '61 in the neck of my Strat before (with a Heavy Blues 2 in the middle) and I actually was surprised how close itgot to the Texas Special neck sound there - it's a great pickup. I'll record clips anda video comparison when I do the swap, but for now, here's a jam with the Area '61 neck.
http://www.youtube.com/watch?v=ouQ_uOnhNQU
Don't mind my epic nerd glasses.
That said, I haven't tried it in a HSH arrangement, but I suspect the Heavy Blues 2 would own there. It's hot, for one, almost double the output of a normal singlecoil, and while it's a little on the dark side for a singlecoil that actually IMO would help it balance better tonally with humbuckers. And, its still fairly stratty:
http://www.youtube.com/watch?v=AOvusD6aoHg
Drew is offline
post #10 of 13 (permalink) Old 06-07-2012, 12:45 PM Thread Starter
thanks a lot man !!! bdw will heavy blues go with basswood ??
bonsuer is offline
post #11 of 13 (permalink) Old 06-07-2012, 03:00 PM
No clue, I only put it in my Strat (alder), and I swapped them for a set of Texas Specials. I would imagine so, basswood is pretty neutral.
Drew is offline
post #12 of 13 (permalink) Old 06-09-2012, 09:07 AM
That is very true, I wish I'd thought of that when I switched pickups in my Ibanez...
post #13 of 13 (permalink) Old 06-09-2012, 03:02 PM Thread Starter
i reversed the paf pro neck of mine ... that means when i am in the 4th position it's the middle and the outside coil of the neck .. strat alike ... now the tone has a sparkly feel with sufficient bass to back it up , replacing the stock single coil will enhance the performance ( i hope)
bonsuer is offline
area , basswood , dimarzio , pickup , rg premium
Middle single coil suggestion for RG 870Z bonsuer Pickups & wiring 12 04-27-2012 02:36 AM
jem copy middle pickup suggestion xxgdkxx Pickups & wiring 8 03-07-2011 04:42 AM
Middle Single Coil Suggestion. ShredGH Pickups & wiring 4 09-30-2009 08:40 AM
middle pick up suggestion for RG jasonbecker88 Pickups & wiring 7 04-22-2006 09:17 PM
middle pick up suggestion for RG jasonbecker88 Pickups & wiring 2 04-22-2006 12:35 AM
