Mixing Seymour Duncan and DiMarzio - Output match? - Jemsite
post #1 of 8 (permalink) Old 06-22-2017, 11:38 AM Thread Starter
Hey there... I'm trying to wake up the sound of my SZ320 a bit and I have a Norton laying around that I'm dying to try out. Before I install it and put on a new set of expensive Elixirs I though I'd ask about how well it will match up output-wise with the stock Seymour Duncan '59 neck pickup that's in it. I can find as much info on SD's site about the output as you get from DiMarzio... just impedance.
Norton (bridge) - 352mv, 12.62k ohms
SD '59 (neck) - no mv info, 7.6k ohms
Is this going to be a close enough output match that I can work with pickup height and get them in the same ballpark?
Thanks for any info or advice!!
FireEagle is offline
post #2 of 8 (permalink) Old 06-22-2017, 03:22 PM
Reviews: 6
Re: Mixing Seymour Duncan and DiMarzio - Output match?
I think there will be no problem at all!
satch_jr is offline
post #3 of 8 (permalink) Old 06-22-2017, 08:41 PM
nice...
paf class pickups are awesome in the neck position (even SD)
Norton has great mids and not too loud ... should sounds pretty nice
enjoy
for pickup height ; start pretty low and then raise them till you get the attack\volume you are looking for
remember when you pick harder it's typically louder
I play with my neck pick up pretty low then raise the screws a bit for a bit more brightness but i like it jazzy
just thought if you are doing the wireing make sure you look up dimazio vs SD wireing
LACS-plus is offline
post #4 of 8 (permalink) Old 06-23-2017, 12:07 PM Thread Starter
Thanks you guys... I might go ahead and give it a try then. I did look up the DiMarzio vs SD pickup colors, so it should be pretty simple. I looked up a wring diagram on-line last night and found the one I posted on the forum here a few years ago. The SZ guitars use a big 4-pole, double throw switch with some strange internal contacts that make and break in different positions. It was hell mapping it out years ago and figuring out the proper wiring.
http://www.jemsite.com/forums/f18/ng...ow-132117.html
I tuned it up last night just to get a good idea of how it sounded, as I hadn't played it in a while. I was actually surprised how good it sounded with the stock pickups, basically a Duncan Distortion bridge and '59 neck. I hadn't played a shorter scale guitar in a while and I really noticed how much easier the bends were... can't wait to get this guitar jazzed up and restrung!
post #5 of 8 (permalink) Old 06-30-2017, 11:19 AM Thread Starter
Just a quick follow up... I put the Norton in the bridge a couple nights ago and threw on a new set of Elixir 10's. Sounds great and the output matches very well! Neck sounds buttery smooth and the bridge is just a little edgier than a vintage PAF sound. Very rich midrange that this mahogany set neck guitar really needed. Good classic rock sound but easily kicks right in to overdrive.
post #6 of 8 (permalink) Old 07-03-2017, 02:27 PM
nice....
post #7 of 8 (permalink) Old 07-05-2017, 07:46 AM
Reviews: 4
You'll be having a killer combination, there!!!
I find the SD '59 an excellent pickup. Very similar to DiM PAF Classic. Crispy and clear. Love it!
I have no experience with the Norton, but from what I read, it will be a great match to it.
You'll just have to pay extra attention to the different colour coding of both brands. Other than that, f*ckin' enjoy!!!
EDIT:
Oh yeah!!! A pair of '59s in a Les Paul definitely kicks it into outter space! Crispy and articulate, they really kick ass with heavier gauge strings.
I have a pair of '59s on a PRS-copy: 25", mahogany body. With Elixir .011s and D#, the d*mn thing explodes every time I use a slight overdrive channel. I mean, it really sings!
Crazy_Guitar is offline
post #8 of 8 (permalink) Old 07-10-2017, 09:09 AM Thread Starter
Thats good to know... I have an old heavy '76 Les Paul and I just don't play it as much as I used to. I played it for years with severely worn frets and after new frets and nut it just doesn't feel like the same guitar anymore. Might be time to jazz up the pickups one of these days and get used to the way it feels again. Thanks!!
59 norton
Dimarzio vs. Seymour Duncan nitro Pickups & wiring 17 01-22-2012 02:54 AM
F/S: Dimarzio and Seymour Duncan Pickups bigrockshow Classified Ads: Guitars and Gear 2 07-31-2009 01:09 AM
FS: Dimarzio Fred, Seymour Duncan SH-6 zeppelin Classified Ads: Guitars and Gear 12 06-24-2009 09:19 AM
WTT: 2 dimarzio HS-3's for Seymour Duncan JB/59 TonyG73 Classified Ads: Guitars and Gear 0 03-15-2009 10:54 PM
Seymour Duncan or DiMarzio Dave67 Pickups & wiring 39 05-14-2008 08:50 PM
