neck pu in bridge position: any issue? - Jemsite
post #1 of 6 (permalink) Old 10-17-2012, 02:46 AM Thread Starter
Hi,
is there any known issue in using a neck humbucker pickup in the bridge position? such as, strings and poles not perfectly aligned?
thanks
higure is offline
post #2 of 6 (permalink) Old 10-17-2012, 02:58 AM
Reviews: 120
Re: neck pu in bridge position: any issue?
No real issues. Just depends if you like the tone or not.
LonePhantom is offline
post #3 of 6 (permalink) Old 10-17-2012, 04:54 AM
Reviews: 15
string/pole alignment issues comes from using a f-spaced pickup where a regular-spaced pickup would be used or vice versa. Example: removing a Dimarzio Evo (bridge) from a Jem and installing it in the neck position of a Les Paul. But like LonePhantom said, it's not really an issue, unless it makes your ears bleed.
silverctr is offline
post #4 of 6 (permalink) Old 10-17-2012, 05:47 AM
I don't think that EMGs differentiate at all between "neck" and "bridge" pickups. I wonder how much difference there really is with other brands.
hlwaller is offline
post #5 of 6 (permalink) Old 10-20-2012, 12:01 AM
I've tried a several Dimarzio neck pickups in the bridge position. They all sounded pretty awful to my ears except for the D-activator X which worked quit well.
moonlight is offline
post #6 of 6 (permalink) Old 10-20-2012, 07:03 AM
What pickup(s) are you talking about, or just in general?
sebastian is offline
neck and bridge
WHat happens when you put a bridge pickup in the neck position? bdk Gear, Equipment, Recording & Off Topic 16 02-10-2017 03:02 PM
D-Activator neck, in UV bridge position Algiman Pickups & wiring 7 09-23-2010 04:58 PM
Breed neck / bridge difference in bridge position marino Pickups & wiring 2 05-25-2005 08:43 PM
an evo Neck in the bridge position??? simonargento All Other Guitars (including Prestige) 0 05-17-2004 11:48 AM
Neck pickup in bridge position? Globbits Pickups & wiring 6 01-27-2003 03:28 AM
