Need Help With JEM70V Pick Ups - Jemsite
post #1 of 1 (permalink) Old 04-25-2016, 07:14 AM Thread Starter
Hi...
I am copying the thread from JEM in the hopes that I can get some ideas:
New member here. I have had my seafoam green green model for a couple months now. I do love the playability of the guitar but have a question on the pick ups.
I know the single coil pick up and switch positions will be a bit quieter than the humbuckers. However, the volume on position 2-3-4 seems to vary, going from normal volume and tone to very quiet on 2 & 4 and almost no sound at all on 3. Sometimes it works fine.
Is there something with the guitar I can look at? I get the same result on all three of my amp rigs, giving intermittent issues with sound quality.
I think it may be in the tone pot. Last night while rolling the tone back and forth it came back to normal for a short while but went away again.
Any help would be appreciated.
Thanks!!
I also found a thread here that made me think about grounding and sure enough, the ground wire had come loose under the back cover. I re-soldered the wire to the same place but the problem still exist.
PS: I was just playing it and you could here an electrical hum, ever so slight, coming into the guitar and then it started playing fine for about a half hour. Then there was slight hum and faded out.
This happens only with this guitar on both my tube and solid state rigs, direct cable in no effects. HELP!
brooksie is offline
pick up "fade"
JEM70V Pick Ups brooksie Ibanez JEM, UV, JS & Other Signature Models 0 04-23-2016 06:29 PM
What Pick ups for me? 6_string_attack Pickups & wiring 2 07-10-2011 04:07 PM
pick ups dazzer All Other Guitars (including Prestige) 3 11-11-2010 11:38 AM
Help With Pick Ups?? adamh1331 Pickups & wiring 1 04-23-2006 09:34 PM
RG7620 picks ups...why bother custom? - the pick ups are awe SHREDlamode All Other Guitars (including Prestige) 8 12-20-2001 02:20 PM
