need help quick....easy question - Jemsite
post #1 of 5 (permalink) Old 01-19-2004, 09:37 PM Thread Starter
kennydoe's Avatar
I'm installing a set of Breeds that came out of a 7DBK in my 550.
I want to split the neck humbucker's outer coil/middle in the #4 position and the Bridge inner coil/middle in the #2 position.
As I look at the guitar standing up, should the Dimarzio logo on the neck pickup be upside down while then bridge logo is rightside up?
~K
kennydoe is offline
post #2 of 5 (permalink) Old 01-19-2004, 10:28 PM Thread Starter
kennydoe's Avatar
Figured it out from the wiring diagram...Dimarzio logos are both right side up. I just hope this middle pickup doesn't give me too much grief.
Thanks Glen.
~K
kennydoe is offline
post #3 of 5 (permalink) Old 01-19-2004, 10:57 PM Thread Starter
kennydoe's Avatar
another question...
The Jem wiring diagram doesn't quite fit here. The single coil is the S1, which has a red, a white & a bare wire.
Right now, the 2 position turnins on the neck inner coil +middle (not quite what i wanted), the 4 position is middle+inner bridge coil (correct) but the #3 position is turning on both inners AND the middle.
What do i need to do here?
~K
kennydoe is offline
post #4 of 5 (permalink) Old 01-20-2004, 09:11 PM
You were doing pretty good here all by yourself for awhile. Maybe if I wait longer you'll come back and answer that question too?
Without the diagram you're using or a pic of the guitar I can't figure out why you have all three pickups on in the middle position. It isn't related to the mismatch on the S1 wires vs. the Jem single. If you want the opposite coil on the neck pickup there are a few ways to get that. Maybe a diagram and a picture and I could get you sorted out. The placement of the logos, to me, is all about the phase relationship of the middle pickup, because you want positions 2 and 4 to cancel hum. Are they cancelling hum now?
frankfalbo is offline
post #5 of 5 (permalink) Old 01-20-2004, 09:16 PM Thread Starter
kennydoe's Avatar
Thanks Frank...I decided to junk the S1 middle pickup and get a Red Velvet instead.
As for now, that middle p'up needs all the help it can get from the other two - lol. I told Chris before...it's like a garage with a Hyundai parked between 2 Lexuses. LOL.
~K
kennydoe is offline
neck humbucker , neck pickup , wiring diagram
Quick and Easy Shred Lick Severinsteelsmith Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 0 10-20-2013 07:58 PM
Thinkin of a quick n easy project... inputs wanted linuxpenguin All Other Guitars (including Prestige) 5 08-16-2011 02:42 AM
Quick and easy wiring question for those in the know. bossfrog Pickups & wiring 2 03-16-2011 10:50 PM
Wiring issue. Probably easy to fix. Help me real quick GuitarEvan07 Pickups & wiring 3 12-21-2008 05:00 AM
Trem removing... just a quick question... - just a quick que Kev Brigden Tech: Setup, Repairs and Mods 1 03-12-2002 03:56 PM
