Need help wiring.. - Page 2 - Jemsite
post #16 of 21 (permalink) Old 03-29-2008, 02:22 AM
Re: Need help wiring..
yeah you are using a 5 way multi switch, i noticed finaly they didnt have it
shoot tech support a email, OR call them tomorow
THEY are SUPER helpfull
just tell them what you are using and htey will send you a detailed exact responce
to simplify you installation, go out and buy a dimarzio 5 way switch...not a multiswitch and not a mega switch, just a regular 5 way
then tell them all that you are using including pots, and pups in detail, they will send you a email, like i said, i got to tech support and asked them it simplified everything for me and in ten munites i was wired up!!!
good luck buddy, or if anyone super knowledgeable on the forum can help you, maybe before that youll get a hold of dimarzio
losgatosrg350dx is offline
post #17 of 21 (permalink) Old 03-29-2008, 04:27 AM
Originally Posted by GP13 View Post
Vimfuego, i just installed my tz according to your diagram. but i havent put a string yet.. i plugged them into my amp without strings to check if it's buzzing on TZ.. it's not buzzing on bridge at all! i've check the pup selector(5way) 1, bridge not buzzing, 2 buzzing, 3 buzzing, 4 not buzzing, 5 buzzing.. i guess there's somethings wrong? is it?
Sorry, didn't see this post before!
When you say you checked without strings by listening to the buzzing, I'm a bit confused, I wouldn't expect positions 1, 2 or 4 to buzz as they are the humbucking selections.
Have you tried tapping the pole pieces with a screw driver, that's the easiest way to check if a pickup is at least connected you should get a loud click from the selected pickups, then you still need to put strings on to check the circuit properly.
As you say position 2 buzzes, then maybe the only problem is that you've selected the wrong coil of the TZ in position 2. If so, then:
bare wire + BLACK of the tone zone= Ground
RED + GREEN of tone zone= goes where the RED of the stock pickup goes
WHITE wire from tone zone = WHITE of the stock
This will select the other coil in position 2, but should leave position 1 the same.
Jim
Vim Fuego is offline
post #18 of 21 (permalink) Old 03-30-2008, 02:45 AM Thread Starter
I email dimarzio for wiring diagram and they were the same set up as vimfuegos first post. but the 2nd wiring that you told me works! a big thank you!!!
GP13 is offline
post #19 of 21 (permalink) Old 03-30-2008, 12:57 PM
good to hear you got it worked out
post #20 of 21 (permalink) Old 03-30-2008, 12:57 PM
wiring always confuses me, so i just go by diagrams as detailed as they are it works for me
post #21 of 21 (permalink) Old 03-30-2008, 09:21 PM Thread Starter
thank you again!
GP13 is offline
coil tap , dimarzio evo , duncan distortion , neck pickup , tone zone , wiring diagram
Custom wiring HELP PLEASE!!! sleepyone Pickups & wiring 5 10-18-2007 07:44 PM
Building wiring scheme with 3 hums dope_maggot Pickups & wiring 1 12-30-2006 04:06 PM
Fishy Js100/1000 wiring Zeppel Pickups & wiring 3 02-20-2005 06:26 PM
Wiring for an RG Allen Garrow All Other Guitars (including Prestige) 5 06-29-2004 06:45 AM
JEM10th Evolution Wiring Diagram..... gerca Pickups & wiring 6 11-18-2002 05:59 PM
