Need help wiring.. - Jemsite
post #1 of 21 (permalink) Old 03-27-2008, 11:23 PM Thread Starter
Need help wiring..
I have my first ibanez the gio's model grx40 (HSS) and i have 1 tonezone just laying around my box.. and i want to install them, .. help please.. thnx!
here is the old wiring for grx40, help me install my TZ?:
GP13 is offline
post #2 of 21 (permalink) Old 03-28-2008, 01:18 AM
Re: Need help wiring..
you have a two conductor humbucker setup
youll have to find a simple hss wiring diagram that includes a 4 conductor
hss setup...then find out what the colors are for your current ibz pups that come with it and substitute them for the 4 conductor wirring diagramin the single pup positions
losgatosrg350dx is offline
post #3 of 21 (permalink) Old 03-28-2008, 03:18 AM
attach
bare wire + green of the tone zone= Ground
black + white of tone zone= goes where the white of the stock pickup goes
Red wire from tone zone= red of the stock
-Rhaab is offline
post #4 of 21 (permalink) Old 03-28-2008, 06:19 AM
Sorry -Rhaab, but looking at the diagram, the red wire of the stock pickup is used for the coil tap and the white for the output. So...
black + white of tone zone= goes where the RED of the stock pickup goes
Red wire from tone zone = WHITE of the stock
Incidentally, there's something a bit odd about the neck pickup in the diagram, it's being tapped like the bridge, is it really a humbucker or is the diagram wrong? Either way if it works, leave it alone!
Jim
Vim Fuego is offline
post #5 of 21 (permalink) Old 03-28-2008, 06:04 PM Thread Starter
ok, i will try them.. thanks guys!
GP13 is offline
post #6 of 21 (permalink) Old 03-28-2008, 11:16 PM Thread Starter
Vimfuego, i just installed my tz according to your diagram. but i havent put a string yet.. i plugged them into my amp without strings to check if it's buzzing on TZ.. it's not buzzing on bridge at all! i've check the pup selector(5way) 1, bridge not buzzing, 2 buzzing, 3 buzzing, 4 not buzzing, 5 buzzing.. i guess there's somethings wrong? is it?
GP13 is offline
post #7 of 21 (permalink) Old 03-28-2008, 11:29 PM Thread Starter
ive found this one from guitarelectronics.com what do you guys think?
GP13 is offline
post #8 of 21 (permalink) Old 03-28-2008, 11:43 PM
you seem to still be using a diferent 5 way selector then showm in this diagram
post #9 of 21 (permalink) Old 03-28-2008, 11:44 PM
you can aim me at
deathaxese7en and i can semi guide you through it
post #10 of 21 (permalink) Old 03-28-2008, 11:45 PM Thread Starter
im still using the same 5 way switch... i've followed Vim Fuego's diagram..
GP13 is offline
post #11 of 21 (permalink) Old 03-28-2008, 11:52 PM
yeah but the switch in the one you posted is a different kind
post #12 of 21 (permalink) Old 03-28-2008, 11:54 PM Thread Starter
yea' i totally forgot about that one.. im not following that one.. i've used VimFuegos
GP13 is offline
post #13 of 21 (permalink) Old 03-29-2008, 12:04 AM
i dont know what went wrong then, if he has the wiring solution maybe you didnt attach a ground or burnt another wire, i dont know why its buzzy
i dont like those 5 ways, id suggest getting a regular 5 way and using dimarzios diagram and then substituting the stock ibz colors for the dimarzio colors
actually if you call dimarzio durring the day time, they will email you a custom diagram free of charge, i had a dimarzio evo br and a duncan distortion neck, and i called them and the tech sent me a diagram where everything went, they are good at helping out customers, but id still suggest using a regular 5 way instead of the multi that the ibz came with
post #14 of 21 (permalink) Old 03-29-2008, 12:16 AM Thread Starter
i cannot find a HSS wiring from Dimarzios site. are you saying i should get other 5 way switch?
GP13 is offline
post #15 of 21 (permalink) Old 03-29-2008, 12:18 AM Thread Starter
this is the original diagram for my guitar.. and i just want to change the bridge with my TZ.. do you have other idea's? beside's from other jemsters here.
GP13 is offline
coil tap , dimarzio evo , duncan distortion , neck pickup , tone zone , wiring diagram
Custom wiring HELP PLEASE!!! sleepyone Pickups & wiring 5 10-18-2007 06:44 PM
Building wiring scheme with 3 hums dope_maggot Pickups & wiring 1 12-30-2006 03:06 PM
Fishy Js100/1000 wiring Zeppel Pickups & wiring 3 02-20-2005 05:26 PM
Wiring for an RG Allen Garrow All Other Guitars (including Prestige) 5 06-29-2004 05:45 AM
JEM10th Evolution Wiring Diagram..... gerca Pickups & wiring 6 11-18-2002 04:59 PM
