Need immediate help with wiring up an evolution into my dbk - Jemsite
post #1 of 12 (permalink) Old 02-20-2004, 10:19 PM Thread Starter
Fry
Sorry, but I am in a big rush, I really need to get this done tonight, and I have never done this before. I am installing an evolution bridge in my dbk, and I need to know if the evo and breed are both the same color coding. Like, can I directly 1 by 1 replace each wire from the evo into the guitar, from the old breeds. I am having trouble explaining it, ask if you don't understand. Thanks.
Fry is offline
post #2 of 12 (permalink) Old 02-20-2004, 10:53 PM Thread Starter
Fry
I have unsoldered all the wires from the breed bridge, and I noticed that the bare wires from the bridge and the neck pickups were wrapped together, and then soldered onto the volume pot. Should I wrap the bare wire from the evo with the neck pickup too, or can I just solder them together?
Fry is offline
post #3 of 12 (permalink) Old 02-20-2004, 11:04 PM
The colors are the same unless Dimarzio made a mistake. The bare wire is to ground and it doesn't matter where you connect to ground, whether you connect it with the other bare wire or straight to that pot or to a different pot for that matter. So long as it connects to ground. Good luck!
frankfalbo is offline
post #4 of 12 (permalink) Old 02-20-2004, 11:34 PM Thread Starter
Fry
Cool, thanks for the reply. It is goin good so far, just getting ready to solder it up. ( so junior high metal shop did come in hand for something)
Fry is offline
post #5 of 12 (permalink) Old 02-21-2004, 12:13 AM Thread Starter
Fry
Where does that wire that is connected to the screw on the body under the bridge pickup go?? I found that it was not connected to anything. Can I just solder it to the volume pot?
Fry is offline
post #6 of 12 (permalink) Old 02-21-2004, 02:03 AM
i soldiered that wire you speak about together with the trem ground to the back of my volume pot
honky_tonk is offline
post #7 of 12 (permalink) Old 02-21-2004, 02:06 AM Thread Starter
Fry
Do you know where it was originally soldered?
Fry is offline
post #8 of 12 (permalink) Old 02-21-2004, 02:11 AM
im pretty sure to the volume ground..i dont think it matters where you put the grounds long as there grounded................im not even sure what that ground is for other than maybe a extra ground for the stock single coil
post #9 of 12 (permalink) Old 02-21-2004, 02:20 AM Thread Starter
Fry
ya, your probably right, It is just my first time putting on pickups, so I'm all concerned about everything. thanks
Fry is offline
post #10 of 12 (permalink) Old 02-21-2004, 02:39 AM
That's the ground wire to the springs (and bridge and strings). It helps keep that funky noise away when you let go of the strings.
bachle7 is offline
post #11 of 12 (permalink) Old 02-21-2004, 03:08 AM Thread Starter
Fry
HOLY CRAP!! I actually did it! I was so nervous when I first plugged it in, I really didn't believe it was going to work. But then I turned the amp on, there was no buzz or nothin, and then I just started playin it, and it was sweet feelin. Oh ya, Evo's and Breeds mix so well too, You can go from a cut through solo sound to a nice rythym sound. It is sweet. I can't say enough about the Evolution bridge, it is just awesome. And now I have a Breed to sell. how much you think I can get for it?
Fry is offline
post #12 of 12 (permalink) Old 02-21-2004, 03:57 AM
Keep it...
If you ever sell the guitar, it's worth more with the original pup... It's a shame when originals get separated...
pinto79 is offline
breed bridge , bridge pickup , evolution bridge , neck pickup , neck pickups
HELP WITH EVOLUTION WIRING chisorg1570 Pickups & wiring 6 04-10-2014 02:04 PM
Evolution set and ym-50 wiring problem kfm946 Pickups & wiring 0 10-30-2011 10:09 AM
IBZ V8 to Dimarzio Evolution Wiring Dragonforce1080p Pickups & wiring 4 08-12-2008 04:01 AM
Evolution Wiring RG462 Pickups & wiring 7 06-15-2007 12:00 AM
