Need some input - Jemsite
post #1 of 6 (permalink) Old 02-14-2005, 03:54 PM Thread Starter
Need some input
I just recently bought an ESP LTD Fm 200. It is a really nice guitar and plays well. It has emg hz pups. And it feeds back like theres no tomorrow. I try moving away from the amp and it still does it, Now I have two there guitars and neither do it at all. One is and Rg570 and the other is a Yamaha. the Ibanez has the v7 v8 and a single coil.
Is there anything I can do to stop this, any procedure that is? Is it the EMG's that are causing this and how come? Are they hotter than normal pickups? Are they anygood? I have heard good things of them.
Also, I have a Brazilian ash petrucci model body that is my next grand adventure. I am a wee bit intimidated at all the pickups available out there. I play ametal style with a Godsmack type tone. I play clean some.
Looking for a all around good dimarzio pickup. Something versitile.
Thanks
tascamrd is offline
post #2 of 6 (permalink) Old 02-14-2005, 04:59 PM
Re: Need some input
I recently bought an Ibanez guitar that feeds back with heavy distortion. I swapped out the pickups for Dimarzio's and it still feeds back. So I'm thinking it has something to do with the design of the guitar and not the pickups. Mine is a Mahogany, set neck guitar. I think your ESP is similar in design.
I know this isn't much help to you but I just wanted to point out that even if you swap pickups it may still be the same.
Rotti is offline
post #3 of 6 (permalink) Old 02-14-2005, 05:11 PM
JJEMMER777's Avatar
Re: Need some input
EMG's are excellent pups. EMG makes "active" and "passive" pickups. The HZ's are passive. Also, the LTD (by esp) aren't really ESP guitars. They are the economy models - not made in USA. (China or Korea I think) I had an LTD a few years ago. I really liked ESP so I figure I'd pick one up cheap (I think I paid $ 350 or $ 400. and maybe get something that played at least comparativley close to an ESP. To my dismay it wasnt anything like a REAL ESP. I suppose for the price it played okay. I had the exact same feedback problem (on any amp) I couldn't play with any real volume and it really annoyed the other players! I dnot know, maybe a combo of the "passive" pickup and the cheaper LTD construction? Then again, I've never proclaimed to be a super geneius in the art of guitar contruction so maybe I am not even close. I guess my advice would be to save up your money a little (or a lot) longer and get the "REAL MCCOY". It may take longer to get your paws on one but it will be well worth the wait in the end. You friends will thank you...as always......you get what you pay for
JJEMMER777 is offline
post #4 of 6 (permalink) Old 02-14-2005, 05:37 PM
Re: Need some input
tascamrd, is this microphonic feedback from the pickups or from sympathetic vibration from the strings? (ie, does it still happen if you mute all the strings?)
If it happens when the strings are muted then you may have a problem with the wiring or the pickups themselves. If not, then perhaps your pickups are too close to the strings. HZ are passive, but from what I recall they are pretty high output.
Algiman is offline
post #5 of 6 (permalink) Old 02-14-2005, 05:46 PM
Re: Need some input
FYI, ESP's aren't made in America either. LTD's are Korean (and have some great models, namely the 1000 series and the higher-end signature models), and ESP's are Japanese.
nocluejimbo is offline
post #6 of 6 (permalink) Old 02-14-2005, 05:54 PM
JJEMMER777's Avatar
Re: Need some input
Thank you for the enlightenment...why was I thinking they were American made...I think I recall seeing that somewhere back when. Also that they will make you a fresh one to your exact specs.....
PEACE:WINK:
dimarzio pickup , petrucci model
I need your input akiragr8 Pickups & wiring 8 12-16-2007 03:00 PM
Need some input GlassCasket All Other Guitars (including Prestige) 8 07-09-2007 06:45 PM
ok now, need some serious input Eddie_UV777 All Other Guitars (including Prestige) 51 12-01-2006 02:34 PM
I need some input here.... Progdude Gear, Equipment, Recording & Off Topic 0 12-09-2005 11:40 PM
VDY Jem - Any input? slug Ibanez JEM, UV, JS & Other Signature Models 8 01-10-2001 07:19 PM
