NEW-7 : B2 vs. N2 Volume, Output - Jemsite
post #1 of 3 (permalink) Old 08-19-2003, 04:30 AM Thread Starter
I just got this used RG7620 and am having problems with the electronics as I said in my other thread. I've now noticed the bridge pickup is not as loud and is much thinner than the neck pickup. I checked this clean into my 4 track, listening through phones and watching the VU meters. So it isn't my ears I saw it on the meter too. I whipped out my Universe for comparison and of course it was normal, loud bridge, slightly quieter neck. The pickups on both guitars are set-up the same height wise.
Is this how the NEW-7's are supposed to sound? I'm thinking I should just gut the electronics on this guitar
CrossingStar is offline
post #2 of 3 (permalink) Old 08-19-2003, 08:34 AM
the New-7s should sound very loud and sharp, so it sounds like that humbucker is accidentally wired in parallel or with the coils out of phase. since i think we've determined in that other thread that your pickup selector might not be stock, it's possible that whoever rewired it did it wrong. [although the wiring for the stock 7620 switch and the _neck_ pickup is more complicated and more likely to cause problems].
as a test, you might try hard wiring the bridge humbucker in standard in-phase, series humbucking mode. unsolder the black and white wires from the switch and connect them for the series wrap [see http://www.stewmac.com/wiring101/hum...g_options.html for color codes]. the red should be hot and the green ground, but it will work if the hot and ground are reversed [it will just change the overall phase of the pickup compared to the neck HB].
if it sounds right, the original wiring and/or switch were screwy. if it still sounds bad, maybe your pickup has different wire colors or is screwy internally.
post #3 of 3 (permalink) Old 08-19-2003, 02:44 PM Thread Starter
cool, thanks for the idea, i'll try that soon.
bridge hum , bridge humbucker , bridge pickup , neck pickup
Volume, Volume, 3 way(blade).... hotrod128z Pickups & wiring 7 12-05-2011 06:51 PM
Low output, where to look first? Takin' a Ride Pickups & wiring 5 09-16-2011 05:14 AM
FS: N-Tune Onboard Tuner - Replaces Existing Volume with Volume/Tuner! (new in box) For_The_Love_Of_Jems Classified Ads: Guitars and Gear 5 08-16-2010 07:03 PM
ERGODYNE LOW VOLUME OUTPUT DAEDAILUS All Other Guitars (including Prestige) 5 03-12-2002 03:24 PM
ERGODYNE LOW VOLUME OUTPUT DAEDAILUS Comments to Ibanez 4 03-12-2002 03:07 PM
