Noise (eletric setup) Question - Jemsite
post #1 of 10 (permalink) Old 11-03-2013, 07:01 AM Thread Starter
This question is from a friend of mine;
On a reissue 62 USA Strat (has 3 vintage single's), on switch position 2 and 4 he says the output isn't silenced. He also comments the connections ( grounding etc.) are correct and wondering it its a switch problem?
mertay is offline
post #2 of 10 (permalink) Old 11-03-2013, 12:39 PM
Reviews: 98
Re: Noise (eletric setup) Question
That guitar came stock with a period-accurate 3-way switch installed, but Fender included a 5-way switch with the guitar just in case the new owner wanted to swap it out.
Did your buddy swap it out, have someone else do it--or is it possible the 3-way is still in there???
AlaskaBat is offline
post #3 of 10 (permalink) Old 11-03-2013, 03:15 PM Thread Starter
Ah yes, he changed the 3 way switch to the 5 way switch himself.
PS; He's very experienced at such things like changing pots, switch etc...
mertay is offline
post #4 of 10 (permalink) Old 11-03-2013, 03:47 PM
Reviews: 98
Have him bust out the multimeter and check connections......
post #5 of 10 (permalink) Old 11-03-2013, 04:11 PM Thread Starter
I'll tell him, thanks
By the way, what came to my mind is (though I have zero experience with single coils) shouldn't one coil's phase (middle coil?) must be reversed to silence the output noise?
Since its a re-issue and shematics came with it, I wonder if its a pickup thing?
mertay is offline
post #6 of 10 (permalink) Old 11-03-2013, 04:39 PM
Question is indeed of the middle pickup is reverse wound. If not there will be hum noise like with the individual coils. However, it won't make crackling noise. In case of that kind of noise there are two possibilities. 1 the switch is dirty and indeed while switching it connects / disconnects. Second there i shorting on the middle pickup / bad soldering of this pickup.
Jouke74 is offline
post #7 of 10 (permalink) Old 11-03-2013, 06:05 PM Thread Starter
Thanks, its pretty late here so I'll tell him tomorrow but one last thing incase needed; Lets say the soldering and switch are ok and turns out the middle pickup isn't wound to eliminate hum on switch positions 2 and 4. Can its phase change by soldering a wire different?
I sometimes read people mistakenly change the phase on humbuckers by soldering a wire wrong somewhere, just wondering if this can be replicated on a single coil.
mertay is offline
post #8 of 10 (permalink) Old 11-03-2013, 06:12 PM
Reviews: 98
Not if it's only got two wires: hot and ground.
4-conductor, yes--as those other two leads are what does it.
post #9 of 10 (permalink) Old 11-03-2013, 06:18 PM
Reviews: 98
The middle is not reverse wound--it is '62 accurate.
"The pickups, which Fender says are reverse-engineered from a particularly coveted ’63 Stratocaster, are made of Formvar wire wound around Alnico 5 magnets. They have a DC resistance of 5.6K and inductance of 3 Henries, putting them at the very low output end of the spectrum compared to, say, the Texas Special Bridge Pickup which tops out at 7.10K or the ceramic magnet Hot Noiseless designed for Jeff Beck, which gets all the way up to 10.4K.
Controls include a master volume pot as well as tone controls for the neck and middle pickups. All three pickups share the same magnet polarity and winding direction. In later years, guitar companies grew hip to the idea of including a reverse-polarity, reverse-wound middle pickup that would serve to create a humbucking effect when that pickup is combined with one of the others, but since this is a vintage-accurate reissue, you have to deal with any extraneous buzz on all pickup settings. Speaking of which, the pickup switch is a vintage-accurate 3-way version – neck, middle or bridge only – but Fender thoughtfully includes a 5-way switch in the age so you can change it over yourself (or have a tech or guitar store do it for you)."
post #10 of 10 (permalink) Old 11-03-2013, 07:34 PM Thread Starter
Thanks guys
mertay is offline
Pickup noise question (F2,C3,F4) metalhead52 Pickups & wiring 3 09-30-2013 12:05 AM
question about buzzy setup rbernie28 Tech: Setup, Repairs and Mods 2 09-11-2010 05:30 PM
nasty noise from prestige rg (that high fret warbling noise that you DONT want) superhairycamel Tech: Setup, Repairs and Mods 10 07-04-2008 08:00 AM
RG trempost setup question? Jemmm All Other Guitars (including Prestige) 2 09-25-2004 06:38 AM
How Do They Do It? - Noise Question Two hands31 Gear, Equipment, Recording & Off Topic 1 01-28-2002 08:36 PM
