ok, ibanez switch H-H, pos1 = neck(hum mode) pos2 =neck(Inner Coil only) - Jemsite
post #1 of 3 (permalink) Old 06-25-2005, 04:03 PM Thread Starter
hmm, newbe here,...
i just wondering and need pure singe coil sound on my rg 1527... (stock, nothing change yet)
i would like to do switching in this way,..
position 1 = Neck (Hum-series)
pos 2 = Neck (Single coil mode)
pos 3 = Both hum
pos 4 = Brigde (Single Coil mode)
pos 5 = Brigde (Hum-Series)
is it possible without adding coil tapper or adding other parts???...
just using stock pups and switch, how the wiring diagram will go???
thanks...
7-request is offline
post #2 of 3 (permalink) Old 07-05-2005, 01:15 AM
Re: ok, ibanez switch H-H, pos1 = neck(hum mode) pos2 =neck(Inner Coil only)
The stock switch is custom-designed and will only give you one combination of sounds. I ran into the same problem when I pulled the mid-position single coil from a 570 and wanted switching similar to my 7620. I'm sure you could get that combination using a 4-pole 'superswitch' but I couldn't begin to tell you how to do it...maybe someone who knows a bit more can shed some light.
rory is offline
post #3 of 3 (permalink) Old 07-05-2005, 11:18 AM
That's a new one to me. I'd ask the people over at Dimarzio how to do it. They're really quick with things like this and they'll even send you the diagram of how to do it as well as info on any other parts that you might need to accomplish it. But know this: no humbucker will sound like a true single coil in split mode, and the crappier the humbucker the crappier the impersonation.
lyconxero is offline
coil mode , coil tap , wiring diagram
FS: Ibanez RX40 neck single coil. white $20 gee Classified Ads: Guitars and Gear 0 05-27-2013 10:41 AM
help!!! single coil for neck cannabis2894 Pickups & wiring 6 01-05-2012 07:17 PM
Ibanez Reb Beach pickguard, Gibson ES-355 Switch Plate & 1966 Fender Neck Plate mayzan Classified Ads: Guitars and Gear 1 03-25-2011 08:57 AM
Switch neck and bridge on ibanez rg-370 IbanezRG-370 All Other Guitars (including Prestige) 9 08-03-2008 01:33 AM
s1 switch & ibanez s coil tap Screaming Wind Tech: Setup, Repairs and Mods 1 03-08-2004 10:14 PM
