Onboard Boost for a Single Coil - Jemsite
post #1 of 4 (permalink) Old 08-06-2013, 06:25 PM Thread Starter
Reviews: 34
I just installed a Bare Knuckle Apache into my 1977 Fender Musicmaster.
It has be single coil and a volume and tone control.
I want to install a small clean boost to drive a small valve amp into overdrive, so in essence a bit like changing from neck to bridge pu in terms of feel.
It has to be on a push/push pot on either the volume or tone. This is important.
So any ideas where I start? I'm guessing that no one else has done this exactly so there won't be a schematic but any help on the components and layout would be appreciated.
Also, is it possible to do it without using a battery?
nickcoumbe is offline
post #2 of 4 (permalink) Old 08-19-2013, 06:02 AM Thread Starter
Reviews: 34
Re: Onboard Boost for a Single Coil
So no ideas?
How about going active then?
I guess I could install an emg afterburner or pa2 boost then attach that to the push/push to switch it on and off?
post #3 of 4 (permalink) Old 08-19-2013, 07:47 AM
You can't boost without a battery. Since you can't add from nothing, you need a battery to add more volts to your signal, always think of batteryless operations as cutting.
So if you want a boost, without a battery, you'll need a high output pickup, then a cut switch. The real trick would be to find a high output single coil pickup that you like the sound of. You'll probably also have to add in a capacitor to retain the high end of the single coil, if one's not built into the knob already.
I believe fender deluxe strats have a volume knob with a button built in under the "volume" label. So maybe you can find that part and a wiring schematic for a place to start?
julzius is offline
post #4 of 4 (permalink) Old 08-19-2013, 06:32 PM Thread Starter
Reviews: 34
Yep, so not possible. I have the pickup installed that I want and I don't want to go high output for the base tone.
Started looking at the option of using an EMG boost in the on position then attaching that to a push push. Looks doable.
bare knuckle apache , bare knuckle pickups , fender musicmaster , on board boost
Consecuences of replacing a true single coil with a hum cancelling single coil? fosi_ Pickups & wiring 20 03-22-2011 02:37 PM
Single coil 7's TMatt142 Pickups & wiring 7 03-06-2008 03:31 PM
Sustainer - Replacing Dummy Coil with Single Coil? F.P.R.O. Pickups & wiring 7 09-12-2007 02:33 AM
Which single coil?? Force Tech: Setup, Repairs and Mods 4 01-07-2006 01:53 PM
Bad Single Coil pup? ChopTart Pickups & wiring 11 12-07-2005 08:41 PM
