PAF Joe & Mo Joe Help - Jemsite
post #1 of 7 (permalink) Old 09-07-2016, 02:58 AM Thread Starter
Hi folks - need some help trying to figure out the issue as I'm no electrician. I can solder and assemble however I can't diagnose electrical issues.
I wired up my JS1 with a new PAF Joe and Mo Joe pickups using the diagram below. Everything works fine, volume, tone, push pull function seem to affect the tone. Issues is everything sounds a bit off, almost like there is a tone cut or a wah is being applied to it. Others times I think the coil is split. It doesn't sound as sharp as any of my other guitars. Best way to describe the tone is in clean tone it sounds almost identical to a telecaster. There is no hum or buzzing. I know something in the wiring is screwy. Pots, capacitors and wiring has all been verified.
http://www.dimarzio.com/sites/defaul...ams/JS1000.pdf
Thanks in advance!
fendrboard is offline
post #2 of 7 (permalink) Old 09-07-2016, 07:29 AM
Re: PAF Joe & Mo Joe Help
Does it sound like the highs are cut out?
Is it muffled sounding?
sebastian is offline
post #3 of 7 (permalink) Old 09-07-2016, 03:55 PM Thread Starter
Hi Sebastian - yes it does. A slight tone cut and muffled. Not as clean as my others. Thx for the the quick reply.
post #4 of 7 (permalink) Old 09-07-2016, 05:18 PM
You may have the tone cap put in wrong.
Try removing the tone cap and see if it sound better.
post #5 of 7 (permalink) Old 09-07-2016, 11:46 PM Thread Starter
Will give it a shot asap work permitting. I'm hopeful! Thx again.
post #6 of 7 (permalink) Old 09-20-2016, 10:35 PM Thread Starter
Not sure exactly what the root cause was however I'm good to go now. I ended up completely disassembling everything and reassemble using a new .022uf. Guitar sound killer. Thank you for your feed back Sebastian.
Regards,
Vs
post #7 of 7 (permalink) Old 09-20-2016, 10:44 PM Thread Starter
I should mention i ended up using this diagram
http://www.dimarzio.com/sites/defaul...200pp_mod1.pdf
FS F Spaced Zebra (cream/black) DiMarzio Mo'Joe and PAF Joe Fun111 Classified Ads: Guitars and Gear 0 09-07-2011 07:37 PM
What middle pickup HSH combines with Joe Moe and PAF Joe? A_D_B Pickups & wiring 4 09-01-2010 12:39 AM
WTB DiMarzio PAF Joe & Mo Joe pups Kelljem Classified Ads: Guitars and Gear 0 07-23-2008 06:12 PM
Dimarzio/Ibz vs Dimarzio (Mo' Joe & PAF Joe) wire colors Big Red Pickups & wiring 1 04-16-2007 07:24 PM
PRS Custom 22 with FRED/PAF JOE or PAF-PRO/ PAF JOE Ced777 Pickups & wiring 4 02-28-2004 11:59 PM
