Parallel wiring help - Jemsite
post #1 of 5 (permalink) Old 07-26-2007, 08:11 AM Thread Starter
Reviews: 3
I want to rewire my RGT42FM to have these sounds:
1)neck full
2)neck parallel
3)neck and bridge full
4)bridge parallel
5)bridge full
I know I'll need a multi pole switch to do this.The problem is,I can't find a wiring diagram for it.I've seen one for wiring a single pup parallel but,not with another pup like I've described.Does anybody have any suggestions?
StevenMikel is offline
post #2 of 5 (permalink) Old 07-26-2007, 09:51 AM
Re: Parallel wiring help
Interestingly, Ibanez has a 5-way switch made for 2 humbucker guitars that would give you four of the positions you want. #4 is the only one you'd be missing, and you'd instead get 1 coil of each pickup in parallel which, in my opinion, is more useful than the bridge in parallel anyway. The part number for it is 3PS1SC5 and the ones I've seen have the characters "2502N" printed on the side. Then, there are wiring diagrams for it all over ibanez.com and they're far simpler than any multi-pole switch is going to be.
Just a thought. Can't help ya if you need the exact combinations listed. Good luck.
djohns74 is offline
post #3 of 5 (permalink) Old 07-26-2007, 11:40 PM
Is there any 5-way switch made by Dimarzio similar to the Ibanez one? One that would allow you to get those five sounds?
sleepyone is offline
post #4 of 5 (permalink) Old 07-26-2007, 11:44 PM
You could check out this one....
http://www.stewmac.com/shop/Electron...er_Switch.html
jemplayer55 is offline
post #5 of 5 (permalink) Old 07-26-2007, 11:49 PM
Or DiMarzio pt# EP-1112 multi pole switch.
humbucker guitar , pole switch , wiring diagram
series and parellel quick question. _allan Pickups & wiring 4 08-02-2006 11:22 AM
Parallel wiring question RG450 Pickups & wiring 0 04-25-2006 12:55 PM
Jem-Like wiring from two Humbuckers? MicJustMic Pickups & wiring 2 06-05-2003 09:26 PM
Series or parallel? Pondering the wiring of 2x12s... Mr Orange Gear, Equipment, Recording & Off Topic 4 04-06-2003 05:28 PM
JEM10th Evolution Wiring Diagram..... gerca Pickups & wiring 6 11-18-2002 05:59 PM
