Phase Reversal & Coil Tapping in RG520 - Jemsite
post #1 of 2 (permalink) Old 02-21-2008, 10:45 PM Thread Starter
I'm considering replacing the stock pickups in my RG520QS with the DiMarzio D-Activator Neck & Bridge pickups and replacing the 5-way with the DiMarzio multipole 5 way per the wiring instructions on their website. Here's my question.
I'm interested in throwing in a phase reversal switch on the neck to get a little wider sonic pallet but i want the phase reversal to work whether I'm using the neck as a humbucker or using either single coil. Could someone let me know how to install that so that I can do that or whether it's even possible. I want to limit drilling as much as possible so i was just going to put in a single toggle switch.
Thanks for any advice.
mythos1980 is offline
post #2 of 2 (permalink) Old 02-22-2008, 12:26 AM
Re: Phase Reversal & Coil Tapping in RG520
use a push/pull pot. it will replace one of your existing pots, either volume or tone. in some instances, both. it will keep you from drilling into the face of your axe and is reversable, whereas drilling....is permanent.
rich
rty13ibz98 is offline
bridge pickup , bridge pickups , toggle switch
Coil Tapping Jem Humbuckers TremoJem Ibanez JEM, UV, JS & Other Signature Models 6 01-11-2007 11:56 AM
Coil Tapping Jem Humbuckers TremoJem Pickups & wiring 0 01-10-2007 06:54 AM
Lesson 13: Tapping overview - right hand technique jem7vwh Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 19 01-11-2005 10:00 PM
Coil tapping the evo's on my 7vwh - can it be done? darthpolster Ibanez JEM, UV, JS & Other Signature Models 1 03-18-2002 11:17 PM
coil tapping vs splitting - what is the differnce ? one less than none Tech: Setup, Repairs and Mods 7 08-18-2001 03:38 AM
