Pickup fitting problem - Jemsite
post #1 of 5 (permalink) Old 01-29-2016, 08:52 PM Thread Starter
Hi all,
I wanted to change the tone zone/true velvet/air norton combo in my Ibanez RG8570SP to a set of Evos. When I fitted them, it seemed as though everything would be wired the same from the instructions - is this the case? Should the new evos be wired in exactly the same fashion as the original combo?
The problem is it just isn't working! All the connections seem good, solid, but there is no output signal from the guitar. Does anyone have any ideas?
Cheers
Craig
Craig_Shaft is offline
post #2 of 5 (permalink) Old 01-30-2016, 04:31 AM
Re: Pickup fitting problem
yes, yes and yes... I had same problem too.
the J custom comes with OTAX switch, right?
After replacing all bridge and neck humbuckers, following the same connection. there is no sound coming. Still a mystery to me why this happened , finally replaced the switch to make it right.
psychoshredder is offline
post #3 of 5 (permalink) Old 01-30-2016, 08:38 AM Thread Starter
I'll have to get the switch out and double check but I think it is OTAX yeah... What do you think is the best 5-way-switch to get for a guitar with a set of evos? I understand some are better quality than others.
post #4 of 5 (permalink) Old 01-30-2016, 01:03 PM Thread Starter
Solved! There was a cheeky little white wire that connects the 5-way selector to the volume pot, and it was hiding underneath the switch as if it was soldered on, but it actually wasn't. It must have pulled off when I took the switch out.
post #5 of 5 (permalink) Old 01-30-2016, 10:07 PM
glad you solved it.
I did the old fashioned way, got CRL switch and doing standard 5 way configuration.
dimarzio , evo , install , problem
Pickup problem? stu_hig Tech: Setup, Repairs and Mods 1 10-25-2009 06:21 PM
Pickup Problem kai715 Tech: Setup, Repairs and Mods 1 01-22-2007 03:54 AM
JEM pickup problem geetarmonkey Pickups & wiring 4 09-29-2004 06:06 PM
Pickup problem Fry Pickups & wiring 7 02-17-2004 05:32 PM
Pickup Problem Two hands31 Pickups & wiring 4 06-11-2002 08:03 AM
