Pickup Installation Question - Jemsite
post #1 of 10 (permalink) Old 01-05-2008, 03:40 PM Thread Starter
If I have a humbucker and I install it the "wrong" way (say, in reverse direction), will the difference sound-wise be very noticeable or barely noticeable?
JeffWiredBeck24 is offline
post #2 of 10 (permalink) Old 01-05-2008, 03:42 PM
Jaden's Avatar
Re: Pickup Installation Question
I dont know about others but I tried that with a set of evo's and didnt really notice a big difference.
I was trying to get the evos to sound good... thats why i did it.
Jaden is offline
post #3 of 10 (permalink) Old 01-05-2008, 04:20 PM
If by install the wrong way you mean physically rotate the pu by 180 degrees then as jaden says you won't notice much difference. This is because when you look at the pu from above the windings still go the same way, (clockwise or anti-clockwise depending on the coil). The only difference you'll hear is because now different coils are nearest the neck or bridge and if the two coils are not identical, say one has slug pole pieces and the other screws, that may make a difference.
If you mean install the wrong way electrically, then that will make a difference but only when combined with another pickup, it'll give the combination a thin brittle sound.
Jim
Vim Fuego is offline
post #4 of 10 (permalink) Old 01-05-2008, 04:28 PM Thread Starter
^Yeah, I meant rotating the pickup 180 degrees. Thanks for the help guys.
post #5 of 10 (permalink) Old 01-06-2008, 06:49 PM
I've had to flip duncans around to get the logos in the right direction, it didn't seem to make a difference.
Axewielder is offline
post #6 of 10 (permalink) Old 01-06-2008, 09:59 PM
most pups sound pretty much the same, some like the d sonic do change
rvai is offline
post #7 of 10 (permalink) Old 01-10-2008, 06:18 PM Thread Starter
I read on the DiMarzio website that the Air Norton changes slightly when put in the reverse direction. Has anyone ever done this? Does the sound suffer or is it a barely noticeable change?
post #8 of 10 (permalink) Old 01-21-2008, 02:36 PM
Reviews: 4
If you use more than one pickup at the time, differences will be very noticable.
Crazy_Guitar is offline
post #9 of 10 (permalink) Old 01-21-2008, 07:09 PM Thread Starter
^You mean when I split the Air Norton with the single-coil?
post #10 of 10 (permalink) Old 01-21-2008, 09:18 PM
Reviews: 4
Not exactly. When you use the Air Norton (be it split or full humbucking) with another pickup... either series or parallel.
air norton
SA2120FM pickup upgrade question twoonie2 Tech: Setup, Repairs and Mods 1 05-06-2007 02:41 PM
Important Pickup Ring Question isida.d Pickups & wiring 2 10-22-2006 06:37 PM
Problems with EMG 85 pickup installation LonePhantom Pickups & wiring 12 08-23-2005 05:03 PM
Parker Fly owners, pickup info. bammbamm Pickups & wiring 6 02-11-2003 09:35 AM
Stupid pickup question - What if there was no pickup... ashlock Tech: Setup, Repairs and Mods 3 07-06-2001 04:12 PM
