Pickup nut length 42 or 43 mm in RGA Prestige - Jemsite
post #1 of 9 (permalink) Old 12-28-2011, 08:08 PM Thread Starter
Iam wanting to replace the stock pups in a prestige rga 321F. The dmarzio dactivators come with two nut sizes: 42.mm(1 5/8. and 43mm 1 11/16. Without pulling the old pups out does anyone know what they might be?
Thanks for any input...
dehanson1 is offline
post #2 of 9 (permalink) Old 12-29-2011, 02:37 AM
Reviews: 11
Re: Pickup nut length 42 or 43 mm in RGA Prestige
Pardon my stupidity. I misread the question AND forgot all my measurements
D.M.RG7620 is offline
post #3 of 9 (permalink) Old 12-29-2011, 08:21 AM
43mm is the width of the nut. the f spaced pickups are more like 52 or 58mm!
rickybaby1985 is offline
post #4 of 9 (permalink) Old 12-29-2011, 11:13 AM Thread Starter
Thanks for the info.... what I meant is that when you order pups for the rga321 prestige from MF it offers them in a 42mm(1 5/ or 43 mm(1 11/16) length of the actual bolt/screw that holds them in...does that make sense? So, I was just wondering if anyone might know the length of that screw since I havnt actually pilled them out. Also, I totally forgot about the pup size..how can I tell if I need standard or F spaced pups? Thanks for any help!!!!!
post #5 of 9 (permalink) Old 12-29-2011, 11:28 AM
Typically, any Ibanez with a trem will need f-spaced pickups in the bridge and neck. However, I've found that fixed-bridge Ibanez use f-spaced pickups, too.
Ryann is offline
post #6 of 9 (permalink) Old 12-29-2011, 02:21 PM
RGTFanatic's Avatar
It doesn't matter which length mounting bolt you get....1mm won't make or break anything.
RGTFanatic is offline
post #7 of 9 (permalink) Old 12-29-2011, 02:25 PM
RGTFanatic's Avatar
WAIT...... the pups on an RG321 are direct mount.....42 or 43mm bolts will go completely through the body. your reading the ad wrong. they're asking about the width of your nut as everyone has pointed out. The RGA321 had a 43mm nut.
post #8 of 9 (permalink) Old 12-30-2011, 03:27 PM Thread Starter
Oh wow, I think your right.....thanks a lot. I havnt played electric in a few yrs.....one more question,. So with the 43 mm not that means Id be getting the F spaced pups right? F spaced in both bridge and neck pup I take it? Thanks again...
post #9 of 9 (permalink) Old 12-30-2011, 04:05 PM
RGTFanatic's Avatar
The neck doesn't matter so much, but since they're priced the same, yes get both in F-spaced. BTW..... you're very welcome.
rga 321 pup replacement
SV5470F Prestige and Roland GK-3 pickup (?) danbergam All Other Guitars (including Prestige) 11 04-12-2011 03:33 AM
Prestige 1550 pickup advice TU BE All Other Guitars (including Prestige) 13 01-23-2011 03:44 PM
S Prestige pickup advice? frolics All Other Guitars (including Prestige) 3 03-07-2010 03:59 AM
New pickup for ibanez prestige rg t320g masterguerrero All Other Guitars (including Prestige) 0 01-06-2010 07:13 AM
Pickup help for mahogany Prestige pierce34celtic Pickups & wiring 8 12-09-2007 02:31 AM
