Pickup problem - Jemsite
post #1 of 5 (permalink) Old 06-03-2011, 11:37 AM Thread Starter
Reviews: 6
Pickup problem
I got a Douglas Spad as a birthday gift from my significant other, and the bridge humbucker has never really worked well. If I touch the mounting screws, I get a lot of hum (no problem on the neck pickup), and if I touch a string tot he bridge pickup, it cuts out. Could it be a bad pickup? just a bad ground? I'm wondering if there's any way to actually solve this problem easily as I am not exactly a whiz with a soldering iron.
Philboski is offline
post #2 of 5 (permalink) Old 06-03-2011, 11:39 AM
Reviews: 98
Re: Pickup problem
Sounds like a ground issue.
AlaskaBat is offline
post #3 of 5 (permalink) Old 06-03-2011, 12:39 PM Thread Starter
Reviews: 6
Re: Pickup problem
That's what I thought too, but everything seems to be well-grounded -- I even pulled the bridge and improved the main ground under the post insert.
How can I check the ground with a voltmeter?
post #4 of 5 (permalink) Old 06-03-2011, 01:21 PM
Reviews: 98
Re: Pickup problem
A ground under a post insert? Never saw one there before. What guitar is this on? For guitars with a trem, I always drill a small hole in the trem spring claw and solder the main ground to that. On non-trem axes, I drill a small hole inside the control cavity, insert a small screw and small washer, and wrap the ground wire to that and solder.
post #5 of 5 (permalink) Old 06-03-2011, 01:30 PM Thread Starter
Reviews: 6
Re: Pickup problem
The ground being under the bridge insert (TOM bridge) is pretty standard from what I understand.
douglas spad , pickup , wiring
Pickup problem? stu_hig Tech: Setup, Repairs and Mods 1 10-25-2009 05:21 PM
pickup problem Nats Pickups & wiring 10 06-23-2005 12:29 PM
JEM pickup problem geetarmonkey Pickups & wiring 4 09-29-2004 05:06 PM
Pickup problem Fry Pickups & wiring 7 02-17-2004 04:32 PM
Pickup Problem Two hands31 Pickups & wiring 4 06-11-2002 07:03 AM
