Pickup problem?? - Jemsite
post #1 of 12 (permalink) Old 05-17-2013, 10:52 PM Thread Starter
Pickup problem??
I had my dad install some new dimarzio pickups in my Ibanez Maxxas guitar. Once I played through my amp it did not sound right. The distortion was very weak and sort of kept fading in and out. On the clean it was a little better. Any ideas?
TECHNOROCKTRONIC is offline
post #2 of 12 (permalink) Old 05-17-2013, 11:26 PM
Re: Pickup problem??
New guy/old fart here.
Sounds like you may only have one side of the pickup working--or a bad solder joint.
Can you post pics of the switch lugs?
Is it on all pickups, or just one?
GodzillaPopcicle is offline
post #3 of 12 (permalink) Old 05-18-2013, 04:26 AM
The pickup/pickups are probably wired in out of phase.
Basically wrong color cable at the wrong place.
Have a look at the wiring diagram and sort it out.
/Magnus
Ibanez-Mag is offline
post #4 of 12 (permalink) Old 05-19-2013, 04:01 PM Thread Starter
Here is a pic..not sure this will help much...
http://imageshack.us/a/img819/7529/picture264e.jpg
post #5 of 12 (permalink) Old 05-19-2013, 05:11 PM
Impossible to see on the photo, sorry.
But if it is DiMarzio should red go to hot (switch), bare (no plastic around it) and green to ground (house of pott) and black and white soldered together and taped over (not touching anything).
/Magnus
post #6 of 12 (permalink) Old 05-19-2013, 05:37 PM Thread Starter
House of pott? I feel like smoking pott after seeing all these colored wires going in all crazy directions...
post #7 of 12 (permalink) Old 05-19-2013, 09:15 PM Thread Starter
UPDATE....I have noticed when i turn the tone knob all the way down the volume goes down a little..is this a tell tale sign of something afoot? My dad swears he wired it exactly the way the other pickups were wired.....hmmm
post #8 of 12 (permalink) Old 05-19-2013, 09:52 PM
Can't tell anything in that pic...other than the fact that you might want to upgrade to a better switch.
post #9 of 12 (permalink) Old 05-19-2013, 10:14 PM Thread Starter
Hey Godzilla..can you recommend a better switch?
post #10 of 12 (permalink) Old 05-19-2013, 11:01 PM
I just looks old and cheap--is it the original?
If not--try an Otax or a Super Switch.
these will give you plenty of options.
post #11 of 12 (permalink) Old 05-19-2013, 11:07 PM
By chance, do you have a multimeter that you can use?
You could start shooting wires to pinpoint the issue.
post #12 of 12 (permalink) Old 05-19-2013, 11:20 PM Thread Starter
Yeah it is the original..
dimarzio problem
Pickup problem Philboski Pickups & wiring 4 06-03-2011 01:30 PM
Pickup problem? stu_hig Tech: Setup, Repairs and Mods 1 10-25-2009 05:21 PM
Pickup Problem kai715 Tech: Setup, Repairs and Mods 1 01-22-2007 02:54 AM
JEM pickup problem geetarmonkey Pickups & wiring 4 09-29-2004 05:06 PM
Pickup Problem Two hands31 Pickups & wiring 4 06-11-2002 07:03 AM
