Pickup resistance vs. output?? - Jemsite
post #1 of 6 (permalink) Old 02-21-2013, 02:48 PM Thread Starter
Just wondering if a higher/lower R value equals louder/hot pickup or is it the other way around?
I know that typically a neck pickup has a lower R value compared to a bridge and is often times louder.
Reason I ask is I have a 3 pickup Epiphone SG Custom and want to put a p90 in the center position. Should I get a neck pickup or bridge. It is likely a neck pickup in there now but what difference would it make???
What happens when a neck pickup is swapped with the bridge, same question I guess?
Thanks!
chopstix21 is offline
post #2 of 6 (permalink) Old 02-21-2013, 03:40 PM
Reviews: 120
Re: Pickup resistance vs. output??
Resistance has nothing to do with output really, it's compression. There are a number of high output pickups with low resistance, as well as low output pickups with high resistance. Output is a combination of magnet type and wire gauge. Resistance has to do with the amount of winds of wire.
LonePhantom is offline
post #3 of 6 (permalink) Old 02-21-2013, 04:34 PM
that is spot on. They only thing i might add is that typically if the DC resistance is super high (20 plus) the pickup will usually be a bit darker sounding because some of the high end is lost because of the high resistance. The same doesn't always apply to a lower resistance pickup but most pickups with 8 or less kohms resistance are a little brighter because they dont lose much high end due to the lower resistance.
again it really depends on how the pickup is made/wound and what type and size magnet is used.
j.arledge is offline
post #4 of 6 (permalink) Old 02-22-2013, 02:02 AM
Reviews: 6
DC resistance also depends on the wiring gauge, but not the magnetic field of the magnet. The bigger is the cross section, the lower is the resistance (for a same number of turns)
satch_jr is offline
post #5 of 6 (permalink) Old 02-22-2013, 07:42 AM Thread Starter
So there is lots of variance then holy! What I am looking for is a P90 that would sound closer to the sound of a bridge P90 but in the center position. I would like to "almost" emulate the sound I would have coming from the bridge of a Les Paul Junior with a P90 in the bridge.
I am not sure what to look for. I am more of an Ibanez guy for sure and I realize I could post in a Gibson forum but I like to do all of my guitar talk here, I value the feedback that I get. It is always a helpful site!
Thanks!
post #6 of 6 (permalink) Old 02-22-2013, 11:42 AM
Reviews: 6
I'm of no help here, I don't know anything about P90s...
satch_jr is offline
Need Help Measuring Pickup Resistance Toddz rgr465 Pickups & wiring 4 04-07-2011 01:18 PM
Same pickup model but different resistance? aznricey Pickups & wiring 9 11-06-2010 07:37 PM
output vs DC resistance amateur_guitarist Pickups & wiring 4 09-17-2005 10:08 PM
Need DC Resistance numbers for V2 pickup!!! freewheeler Pickups & wiring 0 07-12-2002 11:28 PM
Pickup Mounting - & pot resistance, whats the difference? EvilMonkey Tech: Setup, Repairs and Mods 1 03-12-2002 02:10 PM
