Pickup selection help? - Jemsite
post #1 of 7 (permalink) Old 04-28-2012, 01:32 AM Thread Starter
Hi all, I have a project i am building up which has a HS pickup config. I have a vintage Ibanez v-2 bridge pup that came out of my 1980 destroyer. I was thinking of matching it with either a Dimarzio hs3 or a pro track in the neck?
Any advice would be good
kramersteen is offline
post #2 of 7 (permalink) Old 04-28-2012, 02:45 AM
Reviews: 98
Re: Pickup selection help?
Can't really give advice if we don't know what you're after.
http://www.jemsite.com/forums/f35/be...ps-109555.html
AlaskaBat is offline
post #3 of 7 (permalink) Old 04-28-2012, 02:59 AM Thread Starter
Which dimarzio would be a better match to go with the vintage v2?
post #4 of 7 (permalink) Old 04-28-2012, 07:12 AM
Reviews: 120
What sort of music do you want to play, amp, guitars specs, etc? We don't know what to recommend if we don't know this.
LonePhantom is offline
post #5 of 7 (permalink) Old 04-28-2012, 04:57 PM Thread Starter
I play mostly heavy metal and all things related. I have two amps one peavey jsx with a 5150 cab and a peavey bandit.I don't really use to many pedals but if i do its a maxon od9 pro plus and a modded SEM boss ds1.
I think with this guitar i will try and keep the wiring simple, I had either a George lynch setup in mind or just 1vol and a 3way switch.
I have used both pro track and hs4 and either way i wont mind which one goes in, i just would like to know which would be more of a match regarding output?
My multimeter is broken so i cant measure the resistance of the v-2 atm. Does anyone know what it would be around?
post #6 of 7 (permalink) Old 04-28-2012, 05:39 PM
Reviews: 98
Ditch the stock pickup and drop in a Tone Zone and single-sized Air Norton.
post #7 of 7 (permalink) Old 04-28-2012, 05:57 PM Thread Starter
Mate i have two other guitars already with that exact setup. But in this case i have a hs4 and a protrack i need to use.
Never mind i can work it out
guitar pickup help
Need help with pickup selection. I know too much... luthier extreme Pickups & wiring 1 10-22-2011 12:30 PM
Pickup selection Horseman Pickups & wiring 8 04-09-2010 05:42 PM
HSH pickup selection... Bones43x Pickups & wiring 1 11-08-2009 07:18 PM
pickup selection!help!! callen3615 All Other Guitars (including Prestige) 18 03-28-2008 11:17 PM
Pickup Selection Help Please tt0511 Pickups & wiring 14 07-26-2007 03:53 PM
