Pickup Swap for my JEM - Jemsite
post #1 of 6 (permalink) Old 11-06-2016, 01:51 PM Thread Starter
Hey all
Here's the deal. I have an '89 77FP and a '00 7VWH. As things stand my flower pattern is superior in sound. My 7VWH is superior in playability. If I only had my 7VWH I would say it sounds quite nice with the EVOs in there. Then I plug in my FP and I'm blown away by how amazing it sounds. If I was looking for that Vai sound the EVOs would be great. Problem is, that's not my sound. What I like is a crushingly organic sound. I am not a shredder. I play with a couple Swart amps (think Fender tweed). I am a predominately rhythm player. I want my chords to chime. I love to play older stuff such as Pink Floyd, Led Zeppelin, AC??DC, Judas Priest. For newer stuff (although not really all that new) think Radiohead. Like I mentioned earlier, I am in love with the sound of the PAF Pros in my flower pattern. Those pickups kill it. I would just put in PAF Pros but do I want both my JEMs to sound so similar. Will the differences in my JEMs change it up? Do the newer PAFs sound as good as older ones? It's my experience that the new Dimarzio Super Distortions don't sound as good as the older ones.
Other pickups I am considering
Breeds
Gravity Storms
Lollar Imperials (high wound) - I had these in a Les Paul I owned and they were beautiful. I am concerned about their mix with the middle pickup of the JEM which I most likely won't change. That and they are quite expensive.
My JEM (questions asked on the sticky)
Body wood - alder with basswood veneers
Neck wood - maple
Fretboard - ebony
24 frets
Edge LoPro
Amps (I like playing with a lot of reverb)
Swart Space Tone Atomic Jr
Swart Atomic Space Tone
Pedals (I usually play without pedals but I still use my pedals occasionally)
Neunaber Slate/EXP (reverb, shimmer, chorus, delay)
Damage Control Timeline (currently at Strymon being repaired)
Damage Control Liquid Blues
Damage Control Solid Metal
Swart Atomic Boost
Keeley Time Machine Boost
Keeley KO/ALS (Stahlhammer)
Keeley Luna Overdrive
Keeley Son of Fuzz Head
So am I in the right direction with my pickup choices? Are there other pickups I should consider?
Thanks! I look forward to your input.
acstorfer is offline
post #2 of 6 (permalink) Old 11-06-2016, 04:02 PM
Re: Pickup Swap for my JEM
go with the gravity storm set...... a bit more versatile and dynamic than the breed
sound just as good clean as they do driven
I have them in an alder jem copy (I built) and it is my #1 ax right now and has been for about a year
LACS-plus is offline
post #3 of 6 (permalink) Old 11-06-2016, 05:02 PM
that being said I just ordered an overwound set of these to try
http://irongear.co.uk/irongear_pickups_011.htm
after watching this video
https://www.youtube.com/watch?v=1RhO...ature=youtu.be
check out the other sound bites
post #4 of 6 (permalink) Old 11-06-2016, 05:18 PM Thread Starter
I am (and have been) leaning in that direction. I'm going off reviews and I hear great things about both the Breeds and Gravity Storms. I also know someone who played around with an Indonesian JEM and he's blown away by them. He thinks they blow away EVOs. Still that's just what's best for someone else. I believe him though. The EVOs sound good, until I hear them against my PAF Pros.
I'm so tempted to track down an old set of the PAF Pros and put them in. If I do that unfortunately I'd probably never pick up my flower pattern.
I wish I could find some Youtube clips of these pickups that weren't demonstrated with so much gain.
post #5 of 6 (permalink) Old 11-06-2016, 05:19 PM Thread Starter
Wow! They sound amazing! If I ever bother with another Les Paul those pups are high on the list.
post #6 of 6 (permalink) Old 11-09-2016, 09:17 PM
thought i would update you...
the Iron Gear pickups sound great... after some challenges with being stoned and actually soldering them in backwards (yeah go ahead and laugh... it happens) and wanting to tame the brightness in the bridge a little (by lowering the pickup) keep in mind i ordered the over wound set. the neck very nice... similar to the paf pro with less output the bridge nice tight bottom end and crystal clear i am impressed ....
as a sound test I ran them through all of the basic presets on my pod hd sounded great on everything from a tweed to an engl fireball
too bad they don't have different colors in bobbins oh well
enjoy your pickups either way
What would happen (pickup swap) chrisf Pickups & wiring 10 12-08-2011 07:07 PM
Help with pickup swap Captaincohny Pickups & wiring 4 09-29-2009 05:01 AM
Pickup Swap Alopikal Pickups & wiring 2 04-26-2009 03:32 PM
Pickup swap video how to? 70Seven Pickups & wiring 3 05-15-2007 10:32 AM
Just did a Pickup swap, what to look for? Triangle Pickups & wiring 4 06-09-2002 01:08 PM
