Pickup Volumes..... - Jemsite
post #1 of 5 (permalink) Old 08-09-2013, 05:09 PM Thread Starter
Pickup Volumes.....
Hey guys, ....
I have a few RGs etc which have the likes of Breed, Evo etc humbuckers in, as well as HS-2 singles in the middle..... My question is.... On a 5 way selector, the bridge and neck position are quite strong and loud, but as soon as the single is engaged in any position there is a big volume drop.... Enough so, that when I play live i cant use these positions..... How do you guys deal with this?
Sean777 is offline
post #2 of 5 (permalink) Old 08-09-2013, 08:29 PM
mi2tom's Avatar
Re: Pickup Volumes.....
HS is weak, I have a breed and yjm in the neck and no matter how far you screw the bridge pickup away and how near you screw the yjm towards the neck the volume dropout is huge.
Change pickup?
mi2tom is offline
post #3 of 5 (permalink) Old 08-09-2013, 08:59 PM
Combining with a single in the middle is the best option besides using a preamp pedal I guess.
mertay is offline
post #4 of 5 (permalink) Old 08-09-2013, 11:03 PM
Reviews: 120
That's what's to be expected with most single coil pickups. They only cover half the area a humbucker does.
If you want a louder middle pickup, maybe the Seymour Duncan Quarter Pound will work nicely for you.
LonePhantom is offline
post #5 of 5 (permalink) Old 08-10-2013, 02:13 PM
Reviews: 6
Did you swap the cables from your middle pup, I had the same problem (EVO2, virtual 2 middle, Paf Joe). The sound was very low and way too bright. I did not even split the humbuckers... What I did (thanks to DiMarzio): I inverted the cables from the virtual 2: green to selector (hot) and red to ground and it solved the problem.
satch_jr is offline
Balancing Volumes Among Different Guitars theapprentice Pickups & wiring 4 08-07-2010 01:40 PM
Pick volumes Fabius Pickups & wiring 9 08-31-2008 02:45 PM
What do you use to get your distortion at nromal volumes? UV_Ray Polls 23 11-04-2005 02:48 AM
Do you record at loud or low volumes? themaidenmaniac Gear, Equipment, Recording & Off Topic 19 07-29-2005 10:39 PM
Help with Evo Humbucker output Volumes!!!!!!! robbiedp Tech: Setup, Repairs and Mods 2 03-25-2005 01:02 PM
