Pickup wiring help - Jemsite
post #1 of 6 (permalink) Old 03-09-2012, 09:46 PM Thread Starter
Pickup wiring help
I am trying to find a wiring diagram for this combo I want to install in my guitar, but to no avail. I have SD '59 (N) and SD Distortion (B) coming in a few weeks, and I want to install them the following way:
I have a 3-way lever switch and a DPDT switch. I want the 3-way one to change between neck-neck+bridge-bridge, so that's pretty much standard. But, I want the DPDT switch (on/on) to change the neck pickup between series and parallel. If it's possible, I want to use the DPDT switch to affect only the neck pickup wiring, while bridge pickup should stay wired in series (default) at all times.
Could someone post the diagram or hook me up with some sort of a link that shows exactly this, because I am not exactly electronics-savvy, more like a total n00b for this sort of stuff, so I couldn't figure it out on my own if my own life would depend on it. Seymour Duncan colors preferred!
Heavy Jerk is offline
post #2 of 6 (permalink) Old 03-10-2012, 08:47 AM
Re: Pickup wiring help
Put that in between the neck pickup and switch. Then just wire the bridge pickup straight to the 3-way.
xXLinkageXx is offline
post #3 of 6 (permalink) Old 03-10-2012, 03:42 PM Thread Starter
Thanks, but I kinda dumb for this
post #4 of 6 (permalink) Old 03-10-2012, 03:43 PM Thread Starter
You mean to wire it this way, and then just follow the rest of this schematic ?
post #5 of 6 (permalink) Old 03-10-2012, 08:32 PM Thread Starter
Thanks man. I've managed to cook something up. Any good?
post #6 of 6 (permalink) Old 03-11-2012, 05:07 AM
Yep, perfect. Your original post sounded like you had everything else figured out except the mini switch. Nice photoshop, I was about to just draw it out until I scrolled down.
pickup , series parallel , wiring
IBZ/USA pickup wiring help charv712 Pickups & wiring 2 06-10-2010 11:47 PM
INF 1 pickup wiring aloymetal Pickups & wiring 3 10-06-2006 11:06 PM
V2 pickup wiring! modulo Pickups & wiring 1 09-22-2006 06:25 PM
Pickup Wiring for RG lttoler Pickups & wiring 6 03-25-2006 03:18 AM
One pickup wiring Tropps Pickups & wiring 1 12-02-2005 07:30 PM
