Pickups and solid state amps - Jemsite
post #1 of 9 (permalink) Old 02-02-2004, 04:59 PM Thread Starter
Fry
I once heard that hot pickups like evolutions will not work well with solid state amps. Is this true?
Fry is offline
post #2 of 9 (permalink) Old 02-02-2004, 06:13 PM
myth
Nope; it's not true. Evos are passive pups, but even so, there is no reason why any pup wouldn't work in either solid state or tube amps. You may have to adjust your amp's gain settings, but that's true of any pickup.
bachle7 is offline
post #3 of 9 (permalink) Old 02-02-2004, 09:28 PM
it's a myth...
my S540 is equipped with one of the highest output passive humbucker in the market- Seymour Duncan's Invader. so which amp gives the best tone for this guitar? my solid state Peavey XXL...
germX is offline
post #4 of 9 (permalink) Old 02-02-2004, 10:01 PM Thread Starter
Fry
I thought it was a rumor. I have a problem though. My Marshall 250dfx has no gain setting on the clean channel. I run my guitar through a metal master too, and there is no gain setting on that. I think I have too much gain, but how the hell do I adjust it?
Fry is offline
post #5 of 9 (permalink) Old 02-02-2004, 10:57 PM
buying gear that has ajustable gain controls.
RSVampire is offline
post #6 of 9 (permalink) Old 02-03-2004, 12:03 AM Thread Starter
Fry
DAMN!!
Fry is offline
post #7 of 9 (permalink) Old 02-03-2004, 02:05 AM
As a last resort, you might find a knob on either your guitar or amp that says something like "Volume" on it.
bachle7 is offline
post #8 of 9 (permalink) Old 02-03-2004, 03:06 AM Thread Starter
Fry
My guitar sounds insanely weak when I turn the volume down on it though.
Fry is offline
post #9 of 9 (permalink) Old 02-03-2004, 01:51 PM
There are a few things that may help:
1. Make sure you have a 500K volume pot for the evo
2. Add a bypass capacitor across the volume pot if the tone gets bassy
3. Set your amp at the clean level you want, then tweak the dirty gain a little (not sure if this will really help or not).
My amp has separate clean and dirty volumes and my effects pedal can do those things too, so I don't know that I can be much help.
bachle7 is offline
peavey xxl , seymour duncan , solid state amp , solid state amps , tube amp , tube amps
Best Solid State 15-30watt amps for gigs?? vejiita Gear, Equipment, Recording & Off Topic 17 11-10-2008 10:03 AM
Good solid state rack mountable amps? NeglectedField Gear, Equipment, Recording & Off Topic 0 09-16-2008 03:15 PM
Randall Solid State head vs. Tube amps lttoler Gear, Equipment, Recording & Off Topic 13 07-18-2008 02:57 AM
Good solid-state amps (if such a thing exists) SuperJemBoy Gear, Equipment, Recording & Off Topic 6 09-08-2003 11:53 AM
TUBE Vs. Solid State Amps!? DrPuls Gear, Equipment, Recording & Off Topic 23 10-28-2002 03:42 AM
