Please Help: How to Test a Pickup?? - Jemsite
post #1 of 5 (permalink) Old 02-04-2003, 09:11 AM Thread Starter
Obviously I am not an Electrical Engineer (I just play one on TV). My newly acquired Jem's bridge pickup has no signal strength...it is very very faint. I know the switch is dirty and I am going to rewire the whole assembly this week and clean everything thoroughly. While I have it all apart, is there a way to test to see if the problem is with the pickup itself? Can I put a multimeter to the coils or the wires and see if it reads something....what do I do to test whether the pickup is good or bad????
Many thanks....Brad
Gresh is offline
post #2 of 5 (permalink) Old 02-05-2003, 10:37 AM
Try to measure the Resistance... these are given on the Dimarzio site. The resistance of the coils in series should be the value given. Then trie the values of the separate coils. If one coil resistance is infinite, it is still able to give a signal, but this will lack low frequencies. Also check the wires... good luck!
Sadegh is offline
post #3 of 5 (permalink) Old 02-07-2003, 10:43 AM Thread Starter
Downloaded the wiring diagrams from here, bought an allparts five way and a new tip and rewired it all. Your testing hint worked as well so I new the pickup was good. Now she's quiet as a mouse and everything works as new. Love those Evo's!!!!!!!!!
Gresh is offline
post #4 of 5 (permalink) Old 02-07-2003, 01:03 PM
a humbucker is nothing but 2 coils. A coil is a woundede wire. Check the resistance...Indeed even if one wire is broken you will receive some lower resistance. Check and compares the specs of the pup.
jemke is offline
post #5 of 5 (permalink) Old 02-08-2003, 11:57 AM
Cool! Kick ass with it!!!
Sadegh is offline
bridge pickup , wiring diagram
IBZ V7 pickup in the bridge TEST Josephmetal All Other Guitars (including Prestige) 48 11-15-2013 04:06 AM
New Video- pickup test + room tour themaidenmaniac Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 1 04-01-2006 10:19 PM
Jemsite Pickup test Devo Pickups & wiring 16 08-13-2005 03:33 PM
How to test my pickup wiring? sniperfrommars1 Pickups & wiring 5 05-25-2004 05:39 PM
The middle pickup A/B test #1 - i figured it out :) kennydoe Ibanez JEM, UV, JS & Other Signature Models 11 04-13-2001 06:17 PM
