Problem with EMG-JH set - bad buzz when touching components - Jemsite
post #1 of 3 (permalink) Old 06-27-2015, 09:55 PM Thread Starter
Angry Problem with EMG-JH set - bad buzz when touching components
Hi all!
I wired up some new active EMG pickups, and for some reason or another, i dont actually get a sound from the pickups (that i can tell, i dont have strings on yet) but when i touch the ring around the pickup selector switch, I get a REALLY bad buzz.
I do not know what is causing this. Does anyone with more electrical prowess than I have an idea?
Barry
mesamaster is offline
post #2 of 3 (permalink) Old 06-27-2015, 10:43 PM
Re: Problem with EMG-JH set - bad buzz when touching components
there are a few things it could be. A common problem with the quick connect is if you flip the connector over on the bottom of the pickups it sounds really fuzzy and low or no output.
Make sure you have your grounds all connected together and your connector hub is wired right.
What are the pickups in? 1 volume or 2 volume or master tone or one for each pickup?
the volume pot connections have to go in a specific order, one from the switch one to the tone and one going out, and that may vary because of how you have it wired.
i installed the het set before and really hate the quick the connect system. It makes for a messy control cavity.
j.arledge is offline
post #3 of 3 (permalink) Old 06-28-2015, 01:58 AM Thread Starter
Solved!
Stupid (gibson) guitars reverse their green and black wire for output/grnd.
I was trying to route output from the ground wire.
All fixed!
buzz , emg , pickup
the age old problem...fret buzz. drstone Tech: Setup, Repairs and Mods 21 04-18-2010 09:00 AM
Guitar buzz problem... seongkeat Tech: Setup, Repairs and Mods 8 05-17-2007 07:38 AM
another fret buzz problem SandmaN211 Tech: Setup, Repairs and Mods 4 10-02-2006 12:53 AM
Fret buzz problem :S MysticalCrayon Tech: Setup, Repairs and Mods 6 03-24-2006 08:25 AM
set up/buzz problem on my DBK, help. nightfiend14 Tech: Setup, Repairs and Mods 1 11-12-2005 04:25 AM
