Question about the PAFPro in the Rg3120.... - Jemsite
post #1 of 5 (permalink) Old 11-20-2003, 07:58 AM Thread Starter
Is the PAF Pro in the neck position of the neck position of the RG 3120 a neck only pickup. Not sure if the PAF Pro is good in both positions or if there is a 'neck' pickup and a 'bridge'pickup version. In a few days I'm going to have an extra one and I might put into an RG570.
Also, I wasn't to happy with the tone zone in the 3120. In my mind I don't think the Tone zone is the best choice for Mahogany bodied guitars(although others may dig it). I'm wondering if they work much better in the RG570 with the basswood bodie and all.
thanks!
kp69 is offline
post #2 of 5 (permalink) Old 11-20-2003, 10:48 AM
Ditto on the tone zone. I have it in my RX-40 currently, a light bodied guitar which benefits from the TZ’s bass inclination very well.
germX is offline
post #3 of 5 (permalink) Old 11-20-2003, 08:34 PM
Try Air Zone/Breed/Norton/Steveīs Special!
Mandrak is offline
post #4 of 5 (permalink) Old 11-21-2003, 09:32 AM
Re: Question about the PAFPro in the Rg3120....
DiMarzio doesn't make dedicated 'neck' and 'bridge' versions of their pickups, like Duncan does, but you can use many of their common neck pickups like the PAF Pro as low gain bridge pickups -- jazz cats use the Air Norton in the bridge, and the DiMarzio website says that Korn uses the PAF7 in the bridge because the lower output gives a clearer sound with all their amp distortion.
one thing to watch out for when swapping pickups from the neck position to the bridge is whether the magnet was flipped. pickups like the PAF have one coil of screw head pole pieces and another coil of 'slug' flat poles. to install this type of pickup the right way in the neck position, with the screw heads closest to the fingerboard, and to get the right magnet polarities for hum canceling coil cut combinations like the Ibanez 5-way switching for two humbuckers, you need to flip the magnet in the pickup. [unscrew the bottom plate of the pickup, CAREFULLY pop the magnet out, rotate it 180 flat, and slip it back in. the magnet polarity should be opposite of the bridge pickup, so the screw poles of neck and bridge should attract each other if you hold them close].
this isn't an issue for H/S/H configurations, since you want the humbuckers not to have opposite polarity so each of the inner coils will hum cancel with the middle single coil. [unless you use a Schaller Megaswitch, and then you do need to flip...] it also doesn't matter with a pickup like the Blaze II, that has the same pole pieces on both coils -- it will look the same whether installed 'backwards' or not.
so if your 3120 has 5-way coil cut combinations and the PAF Pro screw poles closest to the fingerboard, that pickup probably had the magnet flipped at the factory. if you put it in the bridge position, you might not get all your middle switch positions hum canceling unless you re-flip the magnet.
post #5 of 5 (permalink) Old 11-21-2003, 09:38 AM
I hope this doesn't look like thread-hijacking but it's pretty relevant to my situation..
I recently got an RG620QM (mahogany body) with V7/V8 pickups. I still have a Breed and have an evo on the way. How would the Breed sound in the neck position (or the evo in the neck, with the breed in the bridge)?
Or should I try and swap/trade the breed for something more suitable like an Air Norton or PAF Pro?
I really liked the PAF Pro in the neck of the JEM VBK I had, so I'm thinking maybe I should get one for this guitar, but then it would sound different as it's mahogany.. arrgh
Any ideas?
hexa-db is offline
air norton , amp distortion , bridge pickup , bridge pickups , bridge position , inner coils , mahogany body , neck pickup , neck pickups , neck position , paf pro , tone zone
Question of colored dimarzio pafpro kaskenfer Ibanez JEM, UV, JS & Other Signature Models 4 07-08-2010 12:16 PM
Question about springs on RG3120 SnakeEyes All Other Guitars (including Prestige) 8 06-12-2010 07:45 AM
RG3120 pick-up question RickStar All Other Guitars (including Prestige) 12 11-17-2007 06:59 PM
RG3120 Truss Rod Question AKMG All Other Guitars (including Prestige) 6 08-21-2006 06:15 PM
RG3120 & RGT, why ibanez change the TZ & PAFPRO for JuanCaca All Other Guitars (including Prestige) 5 12-06-2004 11:30 PM
