Re-wiring HSH guitar!! - Jemsite
post #1 of 9 (permalink) Old 02-05-2012, 05:52 AM Thread Starter
Hey guys!
Been a while since i posted here.
Anyway im re wiring my hsh guitar and this is my first time doing this.
ive ordered a new set of duncans (custom custom, hot for strat and alnico pro 2) and while i wait im going to go buy the other stuff.
It gunna be a hsh, 1 volume with treble bleed mod, 1 tone pot and 5 way switch.
So im guessing i go for 2 x 500k pots, but what capacitors should i use and 5 way switch should i go for if i want it to do the ibanez style auto coil tap in pos 2 and 4??
And can someone show me an easy diagram and help me figure out what color wire goes where with the pick-ups? i can only find dimarzio diagrams but im guessing duncan has color coded their ones differently?
thanks guys,
Dave
Horseman is offline
post #2 of 9 (permalink) Old 02-05-2012, 01:11 PM
RGTFanatic's Avatar
Re: Re-wiring HSH guitar!!
switch red for black when using your duncans.........
you want a .047 cap...I use orange drop's
http://www.dimarzio.com/sites/defaul...ams/vai_hs.pdf
RGTFanatic is offline
post #3 of 9 (permalink) Old 02-06-2012, 12:40 AM Thread Starter
thanks!!
and do you have any experience with the treble bleed mod?
from what ive searched there seems to be 2 main ones where you either put a cap and resistor in series or in parallel?
Horseman is offline
post #4 of 9 (permalink) Old 02-06-2012, 11:36 AM
I tried all combination, but the best experience I had was with the third variation - cap in series with resistor. You can read more in my article http://diy-fever.com/misc/guitar-wiring-101/
for those pickups I'd use 0.022uF or even less. My preference is 0.01uF for humbucker guitars. Gives more usable tone range and doesn't get as muddy as 0.022 or 0.047uF caps when rolled down.
bancika is offline
post #5 of 9 (permalink) Old 02-09-2012, 01:20 AM Thread Starter
so do i switch red for black and black for red??
according to this site: http://www.1728.org/guitar.htm
i switch red to black, black to white and white to red?
also does it matter which side i have the 5 way switch? or it just as long as i have them in the right order?
Horseman is offline
post #6 of 9 (permalink) Old 02-09-2012, 02:24 AM
RGTFanatic's Avatar
red for black/black for red.
before mounting the switch, tap each coil with a small screw driver (while plugged in) to see which coil is active in each position. this will tell you how to orient the switch.
LOL...you'd hate my current setup...........068 orange drop with no treble bleed.
post #7 of 9 (permalink) Old 02-09-2012, 04:14 AM Thread Starter
Ive just confused my self looking at other peoples wire color codes.
Shouldnt the black wires on the dimarzio correspond with the white wires on the duncans???
Horseman is offline
post #8 of 9 (permalink) Old 02-09-2012, 12:26 PM
RGTFanatic's Avatar
No, black is your hot out on Duncan's. Red is hot out on DiMarzio's.
Red on Duncans is your south coil tap.
White on DiMarzios is your south coil tap.
Compare the first two. This is direct from Duncan.
post #9 of 9 (permalink) Old 02-11-2012, 08:03 PM Thread Starter
So ive wired it up and added the solo switch from this place:http://www.1728.org/guitar4.htm
and all im getting is buzz... i swapped the leads on the output jack and still the same issue... any ideas? the volume and tone controls work fine, and the solo switch works too but i think its the 5 way switch? or mabe a grounding issue?
Horseman is offline
seymour duncan custom jem
Need to fix guitar wiring ComeAlone Pickups & wiring 2 02-16-2009 08:32 AM
Guitar Wiring Help! RG270L_Guy Pickups & wiring 2 01-18-2008 10:24 AM
Please help me with guitar pu wiring... gear collector All Other Guitars (including Prestige) 8 12-01-2004 09:15 AM
Guitar Wiring 101 What do I need to know? sniperfrommars1 Pickups & wiring 6 05-29-2004 12:44 PM
