RG2xxv Replacement 5-Way Switch (plz) - Jemsite
post #1 of 3 (permalink) Old 10-31-2015, 04:58 AM Thread Starter
Hi,
I've been playing inside my rg and have stuffed up the 5-way wiring.
The only i.d. on it says "5W". I can't grasp the logic of how it works as far as wiring goes and was thinking of replacing it with something more generic that has more support available, like a Dimarzio switch or something.
Does anyone know how to wire these things? If not, what would be a good replacement, that is easier to work with?
I'm at the end of the line as far as trying to figure it out.
I've got a Tonezone in the bridge, Vintage Rails in the middle and Air Norton in the neck. I have all the wiring colours etc worked out for those, just don't get the 5-way.
I'm mid-install of a push-pull volume pot, which is all wired up to switch between series and parallel on the bridge. It was doing this that I've lost my way with the 5-way.
Thanks and suggestions welcome,
Greg.
Greg71 is offline
post #2 of 3 (permalink) Old 10-31-2015, 07:28 AM
Re: RG2xxv Replacement 5-Way Switch (plz)
Greg,
I usually follow the wiring diagrams in the Dimarzio site. They have wiring schematics for a lot of common wiring configurations. Or maybe draw a diagram of where you are currently and what config you're going for someone can help. If you decide to replace your 5 way switch a YM-50 would be a good choice or a Dimarzio would be just fine.
pwsusi is offline
post #3 of 3 (permalink) Old 10-31-2015, 07:43 AM Thread Starter
Ok I found something there, for a hsh which mine is originally. I can see where I may have gone wrong so will give it a shot, otherwise I'll wire it back to stock without the push/pull.
Thanks for steering me to the Dimarzio site.
Greg.
Greg71 is offline
5-way switch , rg2xxv
Ibanez S420 5-way switch replacement Sc0rch Tech: Setup, Repairs and Mods 2 02-13-2015 12:41 PM
Replacement switch for RG2550 Prestige bancika All Other Guitars (including Prestige) 0 07-05-2010 11:23 AM
WTB: Strat replacement knobs/switch tip - purple aywilson Classified Ads: Guitars and Gear 0 04-01-2009 09:52 PM
Replacement Switch Screws snowjan Tech: Setup, Repairs and Mods 7 10-11-2008 09:59 PM
Replacement Les Paul pickup switch Shredder87 Pickups & wiring 1 11-26-2007 06:40 AM
