RG470 PUs replaced EVOs+YJM - pos 2,3,4 hum - please help! - Jemsite
post #1 of 2 (permalink) Old 12-09-2004, 01:35 PM Thread Starter
Hi,
I have run into a bit of trouble with my PU replacement project for an 97/98 RG470, H-S-H configuration, 5-way switch.
I got a couple of EVOs and YJM, trying to get the JEM style wiring. I did as much homework as possible here, and studied past posts & wiring diagrams from Ibanez, DiMarzio etc first.
I installed the PUs, using the hot (red) wires of all 3 PUs for the lugs on the 1st bank on the 5-way switch, tapping the EVOs (white+black) and using the black wire for the YJM for the lugs on the 2nd bank on the 5-way switch.
OK so far, but in position 4 it sounded weak and thin, so I reversed the hot (red) & ground (green) for the bridge Evo and its full sound in all positions. BUT now it hums in positions 2, 3 and 4.
I am not sure what I have done wrong here, the YJM bare wire appears to be soldered on OK to the pot. I *think* I haven't split the YJM into single coil (using red & black wires, others to pot). The YJM should be hum cancelling in position 3 right? Even if the polarity is wrong for positions 2 & 4?
Should I have asked for a reverse phase/reverse polarity YJM or something? Is there anything I can do with the wiring to fix this?
Any help much appreciated!
Cheers,
Wilson
Wilson is offline
post #2 of 2 (permalink) Old 01-01-2005, 01:49 AM
Lightbulb Re: RG470 PUs replaced EVOs+YJM - pos 2,3,4 hum - please help!
Originally Posted by Wilson
Hi,
Cheers,
Wilson
Ok... have a look at this diagram: http://www.ibanez.com/wiring/wire.asp?y=1995&w=RG770G
and this one: http://www.dimarzio.com/Text/Wiring/HumbuckerSingle.pdf
Use the colours for the YJM from the DiMarzio diagram but the solder points from the Ibanez one. The BLACK wire on the YJM should be your hot. If you were to replace the switch with a MegaSwitch from Stu-Mac or AllParts, you could copy the Dimarzio one directly. Bear in mind that you will experience hum in positions 2 and 4 as your are using both coils of the YJM and one from a humbucker. You can avoid that by only using one coil form the YJM, but then it will hum in position 3.
Hope this helped.
pinto79 is offline
wiring diagram
550 replaced 470 470tojem All Other Guitars (including Prestige) 16 05-21-2007 08:29 AM
Has Flo replaced Evo:? projectjem Ibanez JEM, UV, JS & Other Signature Models 12 09-10-2006 06:37 PM
LO-TRS II replaced by EdgePro-II? riconaka Tech: Setup, Repairs and Mods 2 08-03-2006 10:51 AM
Replaced my JEM with this... (J-Custom) zerolight All Other Guitars (including Prestige) 45 09-08-2004 07:30 AM
Pickups are being replaced (EMG 81's). Optimus Prime Pickups & wiring 5 05-22-2003 11:35 PM
