RG927 coil tap wiring? - Jemsite
post #1 of 4 (permalink) Old 03-25-2013, 04:38 PM Thread Starter
So, I installed a Liquifire and a D-Activator recently and wired them up exactly like the guitar came. They're completely awesome, but more options never killed anyone! Here's how they are now:
1. Neck
2. Neck (Parallel)
3. Bridge and Neck
4. Inner Coils
5. Bridge
Does anyone know if there is a diagram that will allow me to have 5 positions of single coil options as well? Something like:
1. North Neck Coil
2. South Neck Coil
3. Inner Coils
4. North Bridge Coil
5. South Bridge Coil
Obviously I'll have to get a push/pull knob of some kind. I have a 5-Way switch with 8 pins in there, if it matters.
I just don't know what I need to change inside the cavity to enable me to do this as far as pots and the switch. Routing is not an option. Thanks!
MicahC is offline
post #2 of 4 (permalink) Old 03-25-2013, 05:28 PM
Reviews: 120
Re: RG927 coil tap wiring?
You're going to need some pretty extensive mods to pull that off I'd imagine. Probably two push pull pots at least. Have a look through the sticky at the top of this sub-forum. There are heaps of links to wiring diagrams. You may be able to find something there.
LonePhantom is offline
post #3 of 4 (permalink) Old 03-25-2013, 08:30 PM Thread Starter
Just did a second read through of that thread I emailed Dimarzio to ask their opinion. Lets see how it goes for this particular setup!
MicahC is offline
post #4 of 4 (permalink) Old 03-26-2013, 02:47 PM Thread Starter
You called it! Turns out it would require stupid amounts of work. I'll just stick with installing a good old push/pull in my volume and go with this diagram Dimarzio gave me
MicahC is offline
coil tap , dimarzio , rg927
RG 7 string premium. RG927 D.M.RG7620 All Other Guitars (including Prestige) 50 06-28-2012 05:54 AM
New pickup wiring help - coil tap skinnyl Pickups & wiring 18 04-28-2012 12:31 PM
HSS Strat wiring w/coil tap? nuno Pickups & wiring 3 09-08-2003 08:07 AM
Evo's and HS-2 wiring help. No coil tap. ericthelight Pickups & wiring 0 06-09-2003 09:00 PM
Wiring my 520 w/ a 3-way & coil tap... NickFlyMan Pickups & wiring 1 01-28-2003 05:46 AM
