RGA72tqm CAP Lz10/20 - Jemsite
post #1 of 14 (permalink) Old 10-10-2012, 01:53 PM Thread Starter
Question RGA72tqm CAP Lz10/20
hello guys
can i change my rga72 pickups and keep the electronics and active eq switch ? what kinda pickup can i use ? active or passive ? (i know the stock pickups is active but i hear they'r can be replace whit passive ones like dimarzio is that true? )
Rainyman13 is offline
post #2 of 14 (permalink) Old 10-10-2012, 05:41 PM
Reviews: 120
Re: RGA72tqm CAP Lz10/20
Of course! Just because you have actives in a guitar doesn't mean that you cannot install passive pickups. You just remove the active gear (pickups, potentiometers, etc, and replace it with passive stuff.
I'm not sure if the RGA72 comes with with a ground wire running to the bridge of the guitar, you'll have to see if there is a wire running to the spring claw at in the spring cavity. If there's not it shouldn't be too hard to run one though.
LonePhantom is offline
post #3 of 14 (permalink) Old 10-11-2012, 09:47 AM Thread Starter
thanks ... but i dont want to remove the active gear (Especially the active eq switch)
i'm not sure about ground wire ... check it soon
post #4 of 14 (permalink) Old 10-11-2012, 06:08 PM
Reviews: 120
So why ask if you don't want to remove it???
post #5 of 14 (permalink) Old 10-11-2012, 06:13 PM Thread Starter
do u read my question ?
"can i change my rga72 pickups and keep the electronics and active eq switch ?"
post #6 of 14 (permalink) Old 10-11-2012, 06:28 PM
Reviews: 120
OK sorry, but as I said, you'll probably need to remove all of the active electronics.
post #7 of 14 (permalink) Old 10-17-2012, 02:30 PM Thread Starter
aha ... ok ... looks like i have no choice
can i replace the switch (active eq) with tone knob (Without doing drills)?
and one more question if i order a set of passive pickup they're come with the electronics or may order separately ?
thanks for answering
post #8 of 14 (permalink) Old 10-17-2012, 03:52 PM
Reviews: 120
I'm guessing you'll be able to swap it out with a tone knob.
No, you'll need to buy the potentiometers and wire separately.
post #9 of 14 (permalink) Old 10-17-2012, 04:14 PM
Reviews: 15
I think I would keep the switch and use it for coil splitting.
silverctr is offline
post #10 of 14 (permalink) Old 10-17-2012, 04:36 PM Thread Starter
thanks again
Is it possible to do this ?
post #11 of 14 (permalink) Old 10-17-2012, 04:58 PM
Reviews: 15
Originally Posted by Rainyman13 View Post
thanks again
Being that it's original use was to turn the active eq on/off, absolutely possible.
post #12 of 14 (permalink) Old 10-17-2012, 05:27 PM
Reviews: 120
I'd put in a Blower switch personally. Install a new 5 way (if the guitar doesn't have a 5 way in the first place) that can do splitting, and the blower switch for taking your bridge pickup up a notch.
post #13 of 14 (permalink) Old 10-17-2012, 07:26 PM Thread Starter
Smile Re: RGA72tqm CAP Lz10/20
thanks alot
5 way for H-H pickups ... just seen on rg premium series ... is that switch selector available to buy ?
do u have wiring diagram for blower switch ?
post #14 of 14 (permalink) Old 10-17-2012, 07:45 PM
Reviews: 120
Yes you can buy that selector switch, I have a couple on guitars. The item number is 3PS1SC5.
Blower switch, here are some blog posts I've written for my own blog and Seymour Duncan
http://www.seymourduncan.com/blog/th...f-your-pickup/
http://www.lonephantom.com/2011/01/s...-modification/
cap lz pickups , ibanez rga72tqme
