SD Distortion pickups on RG 7420 - Jemsite
post #1 of 4 (permalink) Old 01-02-2012, 03:15 PM Thread Starter
Question SD Distortion pickups on RG 7420
Hi Guys, I recenlty bough a pair os Seymour Duncan Distortion for my old RG 7420. Turns out that the SD wiring its a bit different from my actual pickups so I cant wire the new ones the same way, I have been looking for a diagram but no luck.
I want to keep the same configuration that I have with the 5-Way Lever switch, any help is much apreciated.
ecorona21 is offline
post #2 of 4 (permalink) Old 01-04-2012, 03:55 PM Thread Starter
Re: SD Distortion pickups on RG 7420
No help found anywhere... I took my RG to a tech, I shall draw a diagram and post it once I get my guitar back, in case some one needs it...
post #3 of 4 (permalink) Old 01-04-2012, 04:06 PM
it's the same but the color code is different, you could have googled that
bancika is offline
post #4 of 4 (permalink) Old 01-04-2012, 04:59 PM Thread Starter
Did that bro and that didnt help due to the amount of cables the SD has vs the stock... the pickups have different wiring than the stock pickups of the RG 7420. Seymour Duncan support told me that wiring the SD Distortions to the 5 way switch the RG has, is tricky and they dont have a diagram for that and send me links to their forum and another site that charges you for a custom diagram...
The easiest way out was speding 20dlls for a Super switch and follow SD diagram, but nah!!!
Im not a guitar tech nor intent to be, I just know how to play the thing. If I can help others that may look for the same thing I will, once a get my guitar back of course...
diagram , distortion , rg7420 , seymour , wiring
WTT WTS: SD JB, 59N, J90-C pickups, want Super Distortion OklaStar Classified Ads: Guitars and Gear 1 02-23-2009 05:57 PM
FS: Super Distortion S and YJM Pickups Code001 Classified Ads: Guitars and Gear 7 07-01-2008 07:42 PM
S 7420 stock pickups. Flobanez Pickups & wiring 0 06-01-2005 08:33 PM
7620 similar pickups into a 7420..... brutal79 All Other Guitars (including Prestige) 3 01-21-2003 04:17 PM
